EIKI LC-X1 Power House Projector, looking for bulb. Have a used projector, blown bulb, but suspect more issues, trying to find a used bulb to test projector before spending $300 for a new bulb for a projector that may be shot. Anyone have a test bulb or used one. Part no for bulb 610 290 7698. Thanks.
  • 6,993 Answers
the problem here is how to pass the bulb over to you. Many of our experts are scattered all over the world. The problem now would be a distance barrier.
Trying to look for someone that would send the bulb to you would seem nearly impossible.
I would advice the you meet with a tech within your vicinity, the tech might have a bulb or help you check if bulb is really the fault of the problem. The tech will also guarantee you or give you the go ahead of buying the bulb.
I hope you understand my explanation.
Good luck.
Posted on Jun 03, 2010
  • 2,335 Answers
I can't help you source a used bulb for your EIKI LC-X1 projector, but I can point you to where you could save %25 on your costs.
Or even more to buy it from Canada with the exchange rate in your favor.
Given that your unit is worth about 10K, a new bulb may not be such a bad troubleshooting investment.
I hope that helps.
Posted on May 27, 2010
Eiki LC-SD10 Projector will not power on.
any led on ? if no, check thermal switch near lamp house or dried out capacitors in power supply
Aug 20, 2011 | Eiki LC-SD10 Projector Multimedia...
My Eiki lc-x1100 is not displaying very bright. I bought is used from a university and it only has about 900 hrs. on the present bulb. Is there something else that would make it dim? Don't want to...
i would check the physicality of the lamp. once you've removed it, look around the filament of the lamp, and if you notice any dark corrosion build around it, then that's what's causing the dim image. if it looks clean and clear, it might be one of the mirrors within the projector's optical engine.
May 24, 2011 | Eiki LC-X1100 Multimedia Projector
LC-XG200 bulbs where can I get one in the UK? At the moment my image looks blurred is that caused by the lamp or is some other issue?
In the first instance:
Adjust focus of the projector.
Make sure a projection screen is at least 4.1' (1.2m) from the projector.
Check Projection Lens to see if it needs cleaning.
NOTE : Moving a projector from a cool temperature location to a warm temperature location
may result in moisture condensation on Projection Lens. In such an event, leave a
projector OFF and wait until condensation disappears.
Apr 03, 2011 | Eiki LC XG200 Multimedia Projector
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
