Question about Sharp AR-M207E Black and White Copier
Sharp ar-m207 h5-01 error on 2 mashines! after i start the mashine the error apear on screen. i try some reset combinations, but i think i dont press the rite key's. what is the "P" key on this copier? br
  • puricemarius May 27, 2010
    tnx, worked: # * C * 14 START (copy key). :)
    br
  • 328 Answers
Enter code 14 press copy key
Posted on May 27, 2010
Testimonial: "ok"
  • abbas rezazadeh
    abbas rezazadeh May 27, 2010
    P is for jobs not needed.press(# interrupt C interrupt)lcd must shut off.if not try again.when shuts off enter 14 then press copy key.
  • abbas rezazadeh
    abbas rezazadeh May 30, 2010
    we are your friend
Service l6 10
Sharp AR-M207 . Enter these keys one after the other to reset:
  1. # - * - C - *(pound, star, C, star).
  2. The screen will go blank and ask you to enter a code
  3. Enter "14" and press the print button.
  4. It comes back and asks if you are sure(showing "1" as default). Press enter.
  5. Machine should then reset
Aug 21, 2013 | Sharp AR-275 Copier
Call for sevice 4H-00
enter the following on the machine ar-m207 #-___ * ________ C____* very fast the machine would display simulation then type 14 and OK,then press print button.press the press button consistently and machine restart by itself.
Dec 19, 2012 | Sharp AR-M207 All-In-One Laser Printer
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS CHANGED. CODE H3-00 STILL APPEARS.
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Nov 04, 2009 | Sharp AR-5320 Black and White Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
Jan 21, 2009 | Sharp AR-M162 All-In-One Laser Printer
SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Jan 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Message H2-00 in sharp ar m207
You have an open Thermistor in the fuser unit or the code is false caused by power surge. To reset it, press P*C* and hit 14 start, then hit either ok or start again and machine chould reboot and clear code. If code returns then the thermistor is bad. You will have to have your local dealer replace either the themistor or the entire fuser unit.
Aug 08, 2008 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M207E Black and White Copier Logo
1,838 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
