My ipod touch 16gb 2nd gen, screen turned black and now eye can't see a picture and the touch screen is not working turned
  • 3,083 Answers
Go to this webpage and try to reset the ipod, as some of these people explain. http://answers.yahoo.com/question/index?qid=20090105122103AAmFBI3. It looks like the device might have just gone into a standby mode.
Sometimes when this happens the LCD screen has been damaged and has to be replaced. You can get one off the internet and replace it yourself, or you can have it serviced. If the resetting didn't help, here is a YouTube page with videos that explain the replacement procedure. http://www.youtube.com/results?search_query=fixing+a+2nd+generation+ipod&aq=f. It's not a really hard job, just tedious. Hope it just needed resetting, though, and good luck- hope this helps.
Posted on May 27, 2010
I no more itune but i like to unlock my ipot touch 32gb
Apple provides instructions for resetting your iPod on this Web page: https://support.apple.com/en-us/HT204306
May 21, 2015 | Apple for iPod touch 1st 2nd 3rd Gen 16GB...
Ipod touch (2nd Gen) with water damage
The touch screen is not physically attached to the screen, if water was anywhere near the bottom of the ipod it may have triggered the water damage unit inside the bottom. Water also may have leaked into the unit frying the circuits. You'll have to visit an Apple store or Apple.com/support for repair.
Jun 17, 2010 | Apple iPod touch Second Gen (8 GB,...
Charging
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
May 24, 2010 | Logitech Pure-Fi Express Plus...
How do I delete pictures from my Ipod Touch
steps on how to delete pictures from your i-pod touch are stated below. This will work with any iPod touch whether it be a 8gb or 16gb or 32gb. This will also work for both 1st gen and 2nd gen.
This is the first step and will definantly be the easiest. Take your link cable, and plug it into the notch into the computer. Take the end of your cable and plug it up into the I-pod. The side that has the gray circle on the cable will be plugged up face up.
This is the second step. Go into either internet explorer or safari and then go into your files. Go into the file that your store all of your pictures in on your iPod. Then delete the pictures you don't want on your iPod. Or move the pictures to a different folder.
This is the final step. Go into I-tunes and sync your folder with all of your pictures. It will remove the photos you deleted from your iPod.
Good luck.
Apr 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Ipod gen 2 touch scren 16gb stuck on screen with
you should put your iPod to DFU mode and restore it..
use this web address for the instruction on how to do that: http://www.fixya.com/support/r4083816-put_iphone_dfu_mode_restore_3_1_2
Feb 10, 2010 | Apple iPod touch
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Do you know where I can get an apple ipod touch 16gb 1st generation user manual?
you can get manuals at the follwing webpage http://support.apple.com/manuals/#ipod however I could not find the 1st generation manual but 2nd gen or others should help you out.
Nov 19, 2009 | Apple Audio Players & Recorders
I Pressed "Erase iPod" On My iPod Touch 2nd Gen Now It Wont Full Turn Or Be Reconigzed by my computer
put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Jun 23, 2009 | Apple iPod touch
My 1st gen ipod touch has a white screen that's stuck and nonresponsive
my itouch ipod 16gb was slammed down and has a white screen
Apr 04, 2009 | Apple iPod touch
13 people viewed this question
 Grubhead
Grubhead
