Question about Hobart Waterproof Protective Cover fits Item# 164652
What is the name of the chemical/powder after applying on hand the hands remain dry after dipping in water
  • 905 Answers
Talcum powder works to a certain extent.
Posted on Jun 12, 2010
How to clean oven racks
If you mean the straight-in-a-line-parallel-stainless-steel-wire-rod type, we use these methods at home:
General all-round cleaning:
Oven-cleaner spray foam, left to soak to lift grease, then good sponge-down with water-damped cloth / sponge.
Stubborn gunk on racks:
Place racks in empty bath, spray/soak in oven cleaner, or..
pour or squirt engine cleaner / degreaser over entire rack surface, allow to work grease loose, then pour boiling hot water to rinse and dislodge fattiness and carbon.
Ordinary dry washing powder is high in caustic, so also works well.
'Handy-Andy' cream is quite high in ammonia among other unpronounceable chemicals for lifting stuck grease and oils.
Make a stiff, sticky paste of clothes-washing powder and water, then apply to a kitchen 'Zim', ie green scouring pad and mixed with lots of elbow-grease, can restore the racks to former glory.
Rinse well under running water to remove soap.
Otherwise 'bath' the racks in hottest geyser water with washing powder sprinkled on top to soak.
A stiff nylon brush helps to scrub the burnt bits away.
Dec 20, 2017 | Ovens
Tip
Greasy hands cleanup / REALLY CLEAN HANDS
If you use strong hand cleaners and scrub brushes you can avoid both.
Soap will attach itself strongly to grease IF it is given a chance.
Typically people first wet their hands with water then add soap.
The water acts as a barrier to the soap to some degree.
Use any liquid dish soap. You only need a few CCs (cubic centimeters).
Apply the liquid soap to the palm of one hand and then rub your hands together
to spread the soap somewhat evenly. Then use your fingertips to work the soap into the grease for about 10 - 30 seconds per hand. The soap has now chemically bonded with the grease. Place your hands under running water while using a sponge with soft nylon mesh (usually white, not green) to remove the soap. The water will now bond to another part of the soap/dirt molecules and pull them off your hands with the help of the mesh.
This concept can be applied to bathing your body. A little soap, a lot of rub.
Frank in NC
on Oct 27, 2013 | Esca Tech Incorporated D-Lead D-Wipe...
Tip
Applying powder tip
Among your make up kit, you will have your lipstick, mascara, false eyelashes but what is a necessity? Off course your powder but its more important to select the right powder and apply it properly by following the correct method. Powder stops the skin from looking shiny. Translucent powder is considered the best. There are two types of powder and the method to apply them.<br /><br />Loose Powder<br /><br />&bull;Apply powder only after you have completed the application of foundation and concealer.<br />&bull;Take a clean tissue, wipe your brush on it and then use it to remove excess powder from your face.<br />&bull;Dip your powder brush into the powder. Shake off the excess powder.<br />&bull;Brush it on face in the upward direction.<br />Pressed Powder<br /><br />&bull;Apply pressed powder on your face using sponge.<br />&bull;Dab a small amount of powder on a cosmetic puff and apply it to shiny areas or places when your make up has become thin.<br />&bull;Remove extra powder from your face.
on Nov 22, 2010 | Health & Beauty
How to clean stubborn burned on stains in the stainless steel oven
You need to use ordinary soap as a lubricant and a fine steel wool to buff the steel surface. That will remove any built up surface debris completely but you may still have some discolouration of the metal remain.
An automotive polish designed for polishing stainless steel and aluminium (available from auto parts stores) might finish the job for you and remove much of any remaining staining but I would not use a chemical of that type on an inside surface that is used for cooking your food. (Same issue with those dreadful chemical and toxic oven cleaners).
Unfortunately, with use of the unit and heat , you will get some residual discolouration of the stainless steel.
Nov 11, 2015 | Stainless Kitchen Ranges
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
Tip
ANTIQUE CLOCK CLEANING TIPS * The question of how to clean your clock is quite a...
* The question of how to clean your clock is quite a controversial one, as many Master Clock Smith experts have used many different techniques, which can also may be unique to your geographical location.
* Many cleaning solutions and chemicals are suitable. However, We use a water-based formula.
* In deciding the proper solution to use, you will want to observe all hazardous material and EPA regulations in your area. For example, after the cleaning solution or chemical is polluted beyond use how do you get rid of it?
* In years past, it appears that the water-mix formula was the most popular choice. In more recent years, highly active commercial products seem to have taken preference. Currently, we have disposal problems, as many cleaners have been defined as toxic waste. I believe that as the Clock repair business evolves, we should seek and use a less hazardous cleaning solution.
OBSERVE CAUTION
* Always protect eyes and nose when handling cleaning solutions.
* Do not allow movements to remain in the cleaning solution for extended periods of time.
* Use gloves when handling cleaning solutions.
· Special care must be taken with "Bright" movements since these are protected with a "vellum" or thin coat of lacquer. The cleaning solution can loosen and peel this protective coating if the movement is immersed very long. If the lacquer is loosened when cleaning, small bits and pieces of the vellum can clog wheel teeth, pivots and pinions and will require a great deal of unnecessary hand cleaning and effort to remove.image006.jpg
CLEANING THE "AVERAGE" CLOCK
1. Pay very close attention to the type of "clear coat" used on the clock, many clocks use a clear coat that is applied to keep the brass shiny and acid free. If your cleaning solution is too strong, it will remove it unnecessarily. If this happens, it is best to completely remove it and in the end re-apply the clear coat.
2. REMOVE all plastic gear levers and sensitive parts such as a floating balance, as it will tend to trap the solution in the tube. "It will however require a different procedure."
3. I use a 3-step cleaning method:
Step 1. Dip the clock in the cleaning solution mixture. Then brush all large deposits of grease and dirt from the clock, drench the clock in warm water and shake dry.
Step 2. You must [COMPLETELY DISASSEMBLE THE CLOCK as it can not be cleaned properly otherwise] and let soak in a weaker cleaning solution (20 minutes or so will work fine). With a tooth or gun cleaning brush thoroughly clean all wheels, pinions and pivots and un-coil the spring with a Main spring UN-winder.
Step 3. Let it soak in warm water only for 20 minutes, this will neutralize and/or dilute the cleaning solution that is still present in the pores of the metal.
4. Drying: It is very important to thoroughly dry the clock, the theory being that metal is somewhat porous in nature and will tend to hold moisture like a sponge.
DRYING THE CLOCK MOVEMENT
Step 1. Dry with a hair dryer until totally dry.
Step 2. Put in a pre-heated oven at about 180 degrees for about 20 to 30 minutes, this will dry out all moisture from the clock. NOTE: Don't get it too hot, just to the point that you can't handle it is fine.
Hope this tip Helps
R/
David
http://antiqueclock.clockstop.com/CLEAN.htm
on Jan 22, 2010 | Watches
Can you wash your hair before applying texturizer
Hello! Oh please never wash your hair before you apply any chemical services to your scalp. The pores along your scalp remain open after washing your hair (think of it like your pores on your face opening when they are treated with water) in result any chemicals will cause burning across your head.
Best wishes with your upcoming texturizer, hope your hair turns out wonderfully and your scalp can remain happy too!
Dec 31, 2013 | Proline Pro-Line Comb Thru Texturizer...
What's inside chemical hand warmers?
It usually consists of iron powder, activated carbon, salt, water, and some type of absorbent material.
Dec 31, 2012 | Camping, Backpacking & Hiking
After the dishwasher runs there is a lot of soap left in the soap dispenser. I've tried powder and liquid. Liquid is a bit better. I've tried using less soap but there still is a lot left. Also my glasses...
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
May 21, 2010 | LG LDF6810ST Stainless Steel Built-in...
Washing machine doesn't comsume the washing powder.
use liquid detergent, less clothes, larger load size, or put the powder in first and let water fill up. u may want to mix up with your hand or like i do give a twist to the washing device to mix up better. but i did find this the problem when i used generic detergent for they go a little cheaper on the ingrediants try brand name like tide, or gain. cheaper not always better but i find these two work well for me and have a lasting scent.
Mar 29, 2009 | Whirlpool AWM8123 Front Load Washer
Hobart Waterproof Protective Cover fits Item# 164652 Logo
24 people viewed this question
Top Hobart Electrical Supplies Experts
Tim Venetis
Trevor Turner
Bill Boyd
Are you a Hobart Electrical Supply Expert? Answer questions, earn points and help others
