Question about Canon EOS Rebel XSi Digital Camera
I was taking a picture of a moose at Yellowstone and changed lens. I forgot to turn off the camera before switching and the camera just shut down. It won't take a picture or focus the lens in AF mode? I can view my previous shots and downloaded them, but I can't take a picture!!!! And I am at Yellowstone and nowhere near a camera shop!!! PLEASE HELP!!!
  • danstidham May 27, 2010
    ...thanks but the lens is moving fine...but it won't focus or allow the shutter to operate?
  • 2,335 Answers
Try reverting your EOS Rebel XS to its factory default settings:
  1. Under the 'wrench with three dots' icon, select 'Clear Settings' and press SET
  2. Select 'Clear all camera settings', and press SET
  3. Select 'OK' and press SET.
With any luck, this will be enough to jump start life back into your camera.
If not, you can reset the brain of your camera by updating / replacing its firmware. I wrote a Fixya Tip about that which you can find here: Canon Rebel XS Firmware Update WIN.
That ought to bring it back into proper behavior if the settings reset doesn't.
I hope that helps
________________________________
Canon EOS Rebel XS User Manual
Canon Rebel XS Firmware Update PDF
Posted on May 27, 2010
  • Canon Master
  • 3,083 Answers
I guess you've removed the batteries, and reinserted them, in the hope of resetting the camera. The focusing lens could be slightly jammed. You can gently try to hit the side of the camera with the palm of your hand, in the hope of resetting the lens, thereby allowing the lens to rotate and focus, restoring the camera's operational functions. This is all I can suggest, without disassembly, and I hope it works for you. You might also put the other lens back on, and hope the camera resets- turn it off and back on a few times, and see what happens. Sorry this happened on vacation, and I hope you can get it working again, good luck!
Previously i had a problem with the lens as it did not came out but I managed to arrange it.. Now when I switch on the camera it turns off immediatley without allowing me to take any picture or viedo.. The...
Please recheck on the work that was done earlier as the mechanism could be jammed and not reponding to shut down. SInce the lens was taken out and reset if the auto focus/zoom mechanism was struck or jammed this can cause the camera to shut down.
Jun 29, 2011 | Samsung S760 Digital Camera
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
Keeps saying to turn off camera and won't take pictures
What the troubleshooting guide suggest is to turn off the camera and turn it back on which sound like what you have been doing. The cause of this generally points to a camera malfunction between the camera and lens. This makes me believe that either something is restricting the lens from moving like the lens cap is tethered to the camera and tight on the lens so it can't do it's "pre" view and goes into the shut down mode. If the lens has any restriction be it the lens cap, ever ready case or anything that is restricting the lens movement remove it and try it again. I have another theory which is completely opposite to anything even suggested and that is the camera can't read the SD card so goes into shut down mode. If you remove the SD card and check to make sure the "lock" switch is in the unlock position. I'll give you a diagram for this.
The little switch needs to be pushed forward towards the gold contacts.
Diagram
Jan 09, 2011 | FUJIFILM FinePix S1800 Digital Camera
My olympus camera wont take pictures
It sounds as if the lens mechanism is damaged, and when it tries to protract it fails and shuts down.
When you just switch to camera mode, I would try helping the lens come out to get it loose.
If all fails, send in it to be serviced, but expect to pay no less than $80 to get this problem fixed.
Hope I helped,
Tom
Jun 21, 2009 | Olympus FE-170 Digital Camera
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Is there an auto-off function?
I had the same problem and when I held down the menu button and the on button the problem was fixed. Hope it works for you.
Feb 23, 2008 | Konaki DV7-Z Digital Camera
Lens error M425-12 (7f80) appears/ camera shuts down
yea.. i also got sand in my camera and i have thje same problem... there is no help anywhere on the internet for us :(
Feb 18, 2008 | HP Photosmart M447 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Sony cyber shot DSC-W1 Digital Camera
I found an online manual for your camera. Page 84 talks about the USB Mode Normal with the 4 dots underneath. It also show a troubleshooting area for this and it is on page 96. Hopefully this will get your camera working right again. Here is the link to the pdf manual. http://www.docs.sony.com/release/DSCW1.pdf
Aug 25, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
