Question about Car Audio & Video
WHEN I turne the gain up on my audio stereo itturns off+lights fl
WHEN I turne the gain up on my audio stereo it turns off+lights flicker on it to+there are 2wires on plug that diagram dose not show .pioneer DEH-P4100
    Scholar:
  • 111 Answers
Which plug are you talking about? The one from the deck, or the onces that go into the factory wires?
Posted on May 27, 2010
I have feedback when transmitting
Check your audio settings. Feedback is a condition caused when you are transmitting and your audio is coming out of a speaker (headphone) and is picked up by the microphone. Try turning your audio down; reducing your microphone gain; and perhaps using a wind sock (microphone cover) over your microphone to reduce the amount of feedback audio entering into the microphone (manual pg 13).
Aug 01, 2014 | Flightline Fligthline FL-760 VHF COMM...
Flickering screen like bad flouresent bulb
you need to remove the back cover of the tv to gain access the internal part. and then you need to look if their is a loose contact or dry joint connector at the power inverter board for the screen back light. if the connection is good then their is a flickering the back light is need a replacement.
Nov 12, 2012 | Televison & Video
Red Power Protector light
Hi, the only way i can see the amp resets the stereo is that power is dropping. The amp should have its own wires directly to power/battery so as to not affect anything else.
On the protect, try to disconnet all the speakers, make sure the power is OK. If it appears to work, the there could be a problem with speakers/cables. Try a different speaker to see if it works. If the problem continues with speakers off, a different speaker etc, then there is a problem with the amp. Hope that helps
Jul 21, 2009 | Sony XM-2100GTX Car Audio Amplifier
What Hz do i use
The best way to set up an amp is to start with everything on 0 Turn your gain all the way off, then turn the stereo up as loud as u would normally listen to it. With the stereo on, slowly turn the gain up until it sounds the way you want it. As for the Hz settings, for a sub you should have the crossover set to lpf, and the z knob adjusts what frequency your sub will play. Since you have a 10" sub, I wouldn't put it much below 125, because tens can't produce ultra low bass and it could damage the sub. Hope his helps :)
May 02, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Pioneer SX-450 Power Flickering
The power switch needs to be replaced or the contacts cleaned/resurfaced.
As for the lights they probably need replacement also. Check for voltage on them (probably A/C but check for D/C also.
Mar 17, 2009 | Audio Players & Recorders
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
