Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Is there a reset button?
I blew a breaker when I plugged the electorlux dishwasher back in and after I reset the breaker, i couldn't get any power on the dishwasher.. I used different outlets, basically tried everything except tearing it apart.. Right now there is just no power to the dang thing..COuld there be a reset button somewhere on the back or do i need a pro to come in and charge and arm and a leg?
    President:
  • 1,902 Answers
You need a pro to come in and charge you a arm and a leg..
Just kidding
There is no reset button, but there is a fuse in the back of the unit after the power cord that plugs into the back of the machine. Also, you can reset the system by leaving it unplugged for about 15 minutes. But if you popped a breaker then you blew a fuse and need to replace the fuse, your owners manual should give you a schematics to where the fuse is
Posted on May 27, 2010
Wear is the reset button on a samsung DW80J3020US dishwasher?
They don't have one. Disconnect the power, count to 10 and plug back in.
Oct 03, 2017 | Samsung Dishwashers
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
Dishwasher without power
Check the electrical source. Possibly the breaker blew or he plug went bad.
The electrical load varies drastically during a cycle due to heater, motor, etc. If the breaker blew, ONLY reset it ONCE to try as there may have been a serious problem within the dishwasher. ALSO if the unit shares the power with another device that could cause the problem.
Sep 05, 2009 | Bosch Dishwashers
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I have the same issue
Hello Sandiann. First thing to do is unplug or throw the 220v breaker of the supplied AC power. For the Frigidaire or " ELECTORLUX" Pull on the control knobs to remove. Remove the nuts holding the cover in place and carefully remove. Remove the five screws holding the metal support of the controls and lift very carefully. The thermal breaker is located to the top right on the support framing. About the size of a quater with a shaft in the center. The center of the shaft has a black dot. This is the reset button. Your metal support may have a large square opening where you can see the breaker if so reset the breaker with a ball point pen by pressing the black button.
Sep 13, 2008 | Kitchen Ranges
Kenmore dishwasher
Mark, you probabley blew the thermal fuse located on the main board. Easy fix. Part number 8269213. You can ohm it out to be sure. You have to remove the inner panel to get at the control board. The fuse sits on the top side and clips on. Two wires to it. Use the kit with the heavier wires so it doesn't happen again. Check out the attachment.
Jan 21, 2007 | Kenmore 24 in. 16293 Built-in Dishwasher
Problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
1,286 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
