Question about Compaq Presario X1000 Notebook
Usb ports for laptop
I have and old windows 98 version Compaq laptop that does not have usb ports. Is there something that I can get to upgrade it for a dongal key (usb) and printer?
  • 589 Answers
Depending on if it has type I or type II PCMCIA slots, you can get a PCMCIA cardbus USB adapter.
They are relatively cheap on Ebay - about 7 bucks.
Just make sure you get one that is the correct card type, and comes with Win98 drivers.
Posted on Apr 07, 2008
SOURCE:
I have a HP Compaq 6810s laptop and I have a 1gbps network connection for all other PCs in our office but this laptop. I am guessing that the laptop only has a 10/100 network cable port. Is that correct...
a 10 year old laptop. 2007, with XP or vista the DEAD OS.
siddiqui is wrong, there are zero chances this intel chip can go 10 time faster ever. why not look it up first , then answer>?
https://www.intel.com/content/dam/doc/datasheet/82562g-10-100-mbps-plc-datasheet.pdf
nor is second answer right, USB ports, do work. and are faster that 100....MB/S
wlan is upgradable. in all cases. even by country RF rules.
the full service guide is here
http://h10032.www1.hp.com/ctg/Manual/c02014623
no PCMCIA (PCcard slots) HP uses express card slots 2004 and newer LT.
no mini-PCI slots, for LAN.
yes, old PCs do not have Giglan ports, Ethernet 1000)
compaq 6810s you meant 6820 right? cant find anything on 6810s
zero.
the 6820 has Intel 82562G chip for this.
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
the main board has wireless module but no wired, module
the intel chip on board does all that. Ethernet slow.
to upgrade , the only path on stinky laptops is USB ports.
a USB /LAN dongle and express card slot.
the problem is getting USB to fast enough,
it has 3 x USB2.0 (not usb 3, that came out 2 years later)
usb2 is 480Mbit/sec rated ports.
1000
so what can you expect from a USB 2 /lan dongle?
ego this. (ive never tired it on my old LT (cache)
http://www.ebay.com/itm/V-TOP-3-Ports-USB-3-0-Hub-with-10-100-1000-Gigabit-Ethernet-RJ45-Converter-LAN-/263162996726?epid=1674717381&hash=item3d45bca7f6:g:EawAAOSwzPBZnXgT
you can not get 1000 mbit/s speed of any 480port. USB2
1 gigabit per second, (or gigalan speeds)
but try it, see how fast it can go on USB2.
be fun to try and some are only $10 cost, search find, try./
this PC has an Express CARD port.
if luck this might work but are not cheap
http://www.ebay.com/itm/StarTech-EC2000S-StarTech-com-Dual-Port-ExpressCard-Gigabit-Laptop-Ethernet-NIC-/182211847012?epid=691202531&hash=item2a6cac2364:g:kv4AAOSwRgJXj1tC
i can not tell you it works in the HP, at all, why not ask HP
we are not HP here,at all.
this is HP. real.
https://h30434.www3.hp.com/
here is your express slot hiding here. see it, learn about it?
#2 is it. in your service manual, its seen., minehave filler cards there, dummy cards, you remove that and slide in any express card you can find,for version level matched.
finding drivers for XP will a BEACH.
Oct 03, 2017 | HP Compaq Network Adapter
My friend has a compaq laptop without a USB port. How can they hook up a USB device?
First, What operating System is on the laptop?
USB is not supported on Windows 98 or Windows 95. No exceptions.
USB is supprted by: Windows 98SE, Windows 2000, Millenium, XP...
Obtain a PCMCIA (PC Card) with USB & firewire ports... ($20)
http://www.frys.com/product/5850203?site=sr:SEARCH:MAIN_RSLT_PG
Betetr yet, a 4-port USB 2.0 card ($25):
http://www.frys.com/product/5265627?site=sr:SEARCH:MAIN_RSLT_PG
Oct 05, 2009 | Compaq (1456VQLIT) Modem
My old compaq presario wont read my scan disc
Can you use that port to read any other device?What operating system are you using?Did it work previously?Windows 98 you will have to install drivers.Chances are that old computer has a usb 1.0 so it might not work.However try another device in that port or any usb port on the computer to see if any ports are working.Does your scan disk work on another computer.Have you done a windows update recently.Make sure you try all the above.
Good luck
Sep 17, 2009 | Compaq Computers & Internet
I NEED A DRIVER FOR A KINGSTONDATA TRAVELER MEMORY STICK ON THE USB PORT. IM RUNNING A SPECIAL SEWING MACHINE APPLICATIO ON WINDOWS 98 BUT THE USB PORT DOES NOT SEE THE MEMORY STICK. Motherboard Compact MS...
Unfortunately, there are no drivers available for windows 98. Most of your memory sticks will not work on windows 98. Your best bet is to burn your files on a CD and use that instead.
Jun 11, 2009 | Compaq Evo N610C Notebook
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
Jun 09, 2009 | Computers & Internet
Usb 2.0 windows 98
Windows 98 SE supports USB 2.0. The original Windows 98 (gold) or Windows 98 OEM or Windows 98 Upgrade versions which are not SE will not support USB 2.0. Nor is there any way to get USB 2.0 support for these Windows 98 versions unless you upgrade to Windows 98 SE.
Note that the Windows 98 SE upgrade CD will fail upon completion, leaving the SE Upgrade with a corrupt registry, if you try to run the Windows 98 SE Upgrade CD on a Windows 98 system that has a version of IE installed which is higher than IE 4.
Jul 02, 2008 | APC USB Port Version For Windows 98...
Copier Scanner
windows xp, yes. just look for printers which support windows xp.
you may have to upgrade your ram, but many hp machines (as well as other brands) will support pentium II's (10 year old technology) as long as they have 128megs of ram and a usb port. you may also have to update internet explorer (prolly to register the new printer).
the hardware interface matters only when it comes to printer port v/s usb, and most laptops and printers made in the last 5 years will all support usb. make sure the printer does not specify usb 2.0 in its minimum requirements, as this is a fairly new usb standard which was not around 5 years ago.
otherwise, make sure your laptop supports the other minimum requirements for the printer, as the printer's software may not load if the minimum requirements are not meant.
personally, i would recomend an hp, and a simple one at that; the more bells and whistles (such as flash card readers) the harsher the minimum requirements will be.
May 19, 2008 | Compaq Presario 700 470024-192 Notebook
BIOS upgrade?
u can use usb cddrive without update bios but unlike later versions of windows where you just plug it in and it detects it you will have to use an instalation disk for system to recognise device same with usb stick.
what mem do u have and consider xp (need at least 40meg to install)if u can fit 256 or higher ur laughing mem cheap as buttons these days.
Apr 01, 2008 | Compaq Armada M700 Notebook
Compaq pressario 14XL250
Researching your specific machine the ethernet network adapter had at least 5 versions of driver for Windows 98. Only Windows ME driver listed is also the latest version of the Windows 98 drivers. If your drivers were not up to date it is quite possible that your ethernet NIC may need the driver update at this link Presario Notebooks Conexant Combo - Modem/NIC Driver for Windows ME
All your machine's Windows ME drivers and software are listed here. In case you find any other drivers that need to be updated.
Windows ME drivers for your machine
Please respond to this problem with a comment if this does not resolve the issue. There may be more to understand about this problem.
Dec 16, 2007 | Computers & Internet
Compaq Presario X1000 Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
