Question about LG Studioworks 700S 17" CRT Monitor
My monitors picture becume yello, how can i fix it?
  • 4,234 Answers
I'm going to assume that this occurred without moving the monitor, so that the cable is not the problem. Pins will not "bend: or break while conneted.
Them ost comon cause of this is poor connections at the driver transistors for the CRT. These are located on the PC board attached to the neck of the CRT itself. If the connections look good, then the transistors themselves have failed. These are easily replaced and are inexpensive. If you have no experience with these units, please DO NOT attempt this repair. There are dangerous high voltages present inside these units even when unplugged. A TV repair shop should be able to repair this for you and it should not be an expensive repair. I do these quite often for less than $100.
Dan
Posted on May 28, 2010
  • 85 Answers
I could be a problem in the monitor, but it's more likely that you've broken a pin on your VGA cable. Unscrew both screws on your VGA cable (usually blue) and check to make sure all pins are there.
Posted on May 27, 2010
  • LG Master
  • 3,866 Answers
1. check its cable, pins ETC.
A CRT that changes colors likes this is due to a faulty connection bent pins on the d-sub, bad connections inside solder and otherwise, To bad cable itself.
check that out let us know please do leave postive feedback and ratings for the free answer today.
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
The white background has gone yelloe, I
Maybe you could try to restore it to its factory settings.
Apr 17, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
My 24" Flatron Monitor has lost color. Everything else works fine ... any suggestions ?
just unplug the vga port from the computer and then switch on the lcd monitor ideally it shows a red , yello green color transition screens ...if it doesn't then for sure your monitor is knocked off or else you need to troubleshoot your graphics card.
better attach this monitor to another computer and see if it works fine...
Feb 26, 2010 | Computers & Internet
MY MONITOR HAS TURNED PINK
what monitor you have LCD or the picturetube monitor?
If it is a Picturetube monitor, the blue/ yello/ green cathod might have lost.
If they are showing ok then you can adjust your Monitor Data Cable, if needed if may need to replaced. The major probablity here is showing as Data Supply Cable for Monitor needs to be changed, i could help more if i had more details about the problem.
Feb 24, 2010 | Computers & Internet
I have problem in display, sometime it becum black
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Feb 22, 2010 | Nokia 5200 Cellular Phone
Unhooked and moved my computer to another part of my room and the monitor now comes on with the power saver display and button is blue, then power saver display goes off and button turns yellos light and...
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
Sep 29, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Having the same problem as you...
pull the cable from the plug adn you will have the usb connection
Mar 28, 2008 | Samsung NV3 Digital Camera
Hitachi 32HDT20M Plasma Monitor
What are the Temp and Lamp indicator lights doing?
Dec 31, 2007 | Hitachi 32HDT20 32 in. Plasma Television
The screen is white
This is the internal video card of the monitor.
It has either failed, or the cable that connects it to the LCD panel has come out of either the video card or the panel.
Hope that helps =)
Sep 19, 2006 | BenQ FP757V2 (Black, Silver) 17 in. Flat...
LG Studioworks 700S 17" CRT Monitor Logo
109 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
