Question about Frigidaire FRS26H7CS Side by Side Refrigerator
Freezer & Refrig does not get cold
Water drips down the Freezer panel from the bottom of the insert where ice and water are dispensed.
Just replaced $42.00 water filter in the refridgerator front
    Novelist:
  • 127 Answers
Without a model number to check out what else might be in that area of the door i'd say a piece of tubing from the water source is leaking, or you are getting ice melt from inside somehow making it out through that panel now. i believe the water for the door comes in through the bottom of the freezer door and works its way up to the dispenser area, the solenoid for the water inlet is behind the fridge near the bottom (you'll see the water tubing).
more likely somethings just not fitted or aligned properly and waters making it out someplace it shouldn't.
best of luck to ya
Posted on May 27, 2010
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before:
Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)"
I hope this helps you out!
Apr 09, 2017 | Water Filters & Coolers
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Water is dripping into the bottom of my fridge. I have cleaned and vacumned the coils. How do I access the drain to see if it is frozen?
Remove the ice maker and back panel in freezer.1/4 inch nut driver to remove screws. there are 3 screws for the ice maker 2 on the back wall and 2 on the bottom panel. Use a hair dryer to melt ice block.All water will flow down into drip pan under fridge. May overflow use a turkey baster to remove water from pan. Pour hot water onto drain until the water flows freely into the pan.
Jun 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Frigidaire FRS26H7CS Side by Side Refrigerator Logo
112 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
