Question about Mitsubishi WS-65809 65" Rear Projection Television
Hello again well i tried holding both buttens but the green light blinks and does not do anything
  • Mitsubishi Master
  • 8,617 Answers
If it blinks continually without stopping its due to 4 bad 1000uf @ 35V capacitors on the DM board and they wiill need to be replaced as thats what makes the light continually blink. If you need more info please let me know.
Posted on Apr 07, 2008
SOURCE:
Keep getting error code 5200, turn off and turn on again
Hello, you need to reset the waste ink counter:
  1. Start with the printer OFF
  2. Hold down RESUME and then hold down POWER
  3. release RESUME
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Number of presses Light color Function 0 presses green Test print (or exit service mode on i960) 1 press orange EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses green EEPROM initialize 3 presses orange Reset waste ink counter
Jul 28, 2014 | Canon i850 InkJet Photo Printer
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
3. Release RESUME
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Operator Error Canon i850 printer
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Phone only showing time and battery......
try 2 format it by pressing and hold it till it comes formatting (green key+*+3and swich the on butten and hold it
May 03, 2008 | Nokia 7370 Cellular Phone
HD1080 65inc.mitsubishi
Hello hope. Try pushing in the input and menu buttons on the set and hold them both in together for 8 seconds to see if the Led will blink a two digit code then let me know what that code says. I can get you a link where to get a new power supply, but that may not be your problem. Try this test an see what the led blinks if anything then let me know I will try to help you determine whats wrong. I am a specialist with mitsubishi projection units.
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hp Pavillion a420n blinking light
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
Mar 25, 2008 | HP Pavilion a420n PC Desktop
Dont have a remote
A green blinking light usually indicates an internal problem. The service person can use the pattern of the blinks to determine the problem.
Jan 08, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
