Question about IBM ThinkPad T23 2647 Notebook
Laptop locksup and shows something like a lock &1 & something that looks like a disc
  • 6,831 Answers
Hello
Ok, this is a clarification request:
Do you get into windows, or, does the message appear before you can access windows.
Also, please be so kind to let me know the exact message which you are promped with.
Also, please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Posted on May 27, 2010
  • 1 more comment
  • buzanawalt May 27, 2010
    I can't get pass what I think is administrator password period let alone windows start up
  • Andrea Lock
    Andrea Lock May 27, 2010
    OK, what versoin of windows are you using?
  • Andrea Lock
    Hello
    Ok, if you are using Windows XP, you are in luck if it is only a login password which you are promped with.
    Have a look at THIS video, you will be able to remove the password and login to windows again.
    Kind regards
    ANdrea
How can I do a system restore on my Dell latitude dD620 laptop if its locked.
Best why to do that is put a restore disc and push repair it will restore the computer unlocking it free from password
Apr 14, 2017 | Dell Computers & Internet
My sony vaio vpceh26en shows burn a disc option when entering a data disc?
CHECK THE FORMAT OF THE DISC AND OPTICAL DRIVE IF BOTH FORMATS ARE EQUL ONLY YOU CAN HEAR THE AUDIO PLS DO CHECK WITH YOUR OS
Mar 31, 2013 | Computers & Internet
No output to rear jacks
It's hard to do this long distance, but I have a feeling the problem is with your disc or your laser, not your connections. A distant third possibility is the deck's transport.
First, plug the deck into an amp, and make sure you have connected it to the right place. (It is very easy to get tripped up by tape inputs and tape monitors.)
I suspect that you accidentally erased the disc. So let's check. Play an MD that you are SURE has something on it and see if anything at all is coming through the amp and speakers. Be sure to look at the display to see if the disc is actually playing a track.
Then try recording something on the disc you have. Be sure to enable the disc to record. The little white tab on the bottom left has to be closed. If it is open the disc will not record. Make sure it is all the way closed, too. Do this by opening it and then closing it with a thumbnail or small screwdriver.
When you record, see if the record meter shows that something is actually going into your deck.
You should also see if the metal protective tab is still there (front right center), and try to jiggle it to see that it is not stuck. Don't force it - just jiggle it. Memorex discs are famous for having that part fail. That part has to slide down for your disc to play or record. This will make a lot more sense if you take the lid off your deck and watch the mechanism work.
1) Be sure there is something on your disc.
2) With the lid off see if the disc is actually turning.
3) Look at the display to see if it tells you that the disc is playing.
4) In case you erased your disc, try recording something on it or on a different disc). Check the display as it does so, and look at the transport to see if anything is turning.
If nothing is turning or moving, it MAY be dirt or it may be grease where grease shouldn't be or no grease where grease should be. That is unlikely, but check it out. What do you have to lose?
If everything is moving but nothing records and nothing plays back, your laser is dead. And they are not cheap. Fortunately, there are a gazillion MD decks on eBay.
When all else fails, read the operating instructions - http://www.minidisc.org/sony_mdsje330_manual.pdf
Dec 14, 2011 | Sony MDS-JE330 Mini Disc Player
HAVING TROUBLE CLICKING ON SOMETHING AND COMPUTER LOCKSUP SAYING CLOSE PROGRAM OR WAIT!!!THIS HAPPENS OFTEN!! HPdv7 6163 i7 windows 7
Probably viruses. Try to load Windows in Safe mode, if everything is OK, there is a problem with system or viruses. Power on laptop, press F8 and hold until you get Windows loading options, and choose Safe mode.
Sep 04, 2011 | HP Pavilion dv9000z Notebook
I have hp 530 laptop .but my brother change poweron password in my laptop .he forgot the password..can i solve this problem?
You need to remove the access panel on the back of the laptop, locate the jumper labeled E49 and remove from positions 1 and 2 and put it on 2 only. Replace the cover and boot up, this should get you past the password.
Please leave feedback if you find this helpful. Thanks.
Mar 18, 2011 | HP 530 Notebook PC
How to put off number keys on my laptop? my laptop has both numbers n letters on a few keys
most thinkpads use 'hold down shiftkey and press Numlk/Scrlk key' should also toggle a led off & on next to the caps lock led. looks similar to caps lock but the arrow has a 1 in it for number lock when the caps lock uses the letter 'A'
Dec 23, 2010 | Lenovo ThinkPad W500 Notebook
When I write text on the laptop keyboard, only numbers show but no letters. what to do?
Try reset your laptop. Remove the battery and allow 1 hour before re-inserting the battery. Then get back to me what happen.
Nov 04, 2010 | IBM Thinkpad 560 Series Laptop 20h4241...
Toshiba L350 series laptop shows "windows failed to start" screen when booting up & goes to a completely blank screen afterwards. Tried using recovery cd & can't get C prompt to come up. Need...
Shut down the laptop, make sure that no light is lit up. Before booting it back up, press and hold the F12 button. It will lead you to boot options. Open up your DVD drive and insert Disc 1 of recovery then make sure you select the ODD or the dvd drive to boot up. This will start the recovery process.
Other models has Icons for boot options. Make sure you select the single disc option to boot the ODD.
Hope this helps.
Dec 20, 2009 | Toshiba Satellite L350-ST3701 Notebook
Acer3100 laptop comes on but no screen
Fan needs to be clean plus your CPU clocking must be check by expert. Power supply is good? did you take a look at it? Under the laptop required Power shows, if your AMP loose or less your laptop will
faintdown. Your battery migth also **** all the power so laptop performans gets down. Your lcd inverter also could be faulty. Bad caps also issue for this, You need OHM meter to test some power issues.
Goodluck or show to expert
JMC
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
IBM ThinkPad T23 2647 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
