LG air conditioner spitting out water through vents
My AC is spitting out water through the vents, my concern other
than why this is happening, is if there might possibly be any
coolant leaking out with the water, and also with all the water out
is there a possibility that there might be mold growing inside
the unit? What should I be most concerned with regarding this
problem?
Thanks
Mia
  • 1 more comment
  • Anonymous Jun 12, 2008
    why is leak water on the vents
  • tat2jnky1 Jul 29, 2008
    im having the same problem with my goldstar wg5005r
  • William Burruss
    William Burruss Jul 12, 2014
    i have pulled my ac all the way apart and cleaned it and it still isnt working properely i have no idea what to do but it isnt any betteri am stilling trying to fix the problem
  • 725 Answers
Hi Mia
I would worry about coolant .. your problem is that the drain in on the outside is pluged or the AC is not installed correctly and is not draining to the outside as it should...
hope it helps
let me know
Posted on Apr 09, 2008
  • William Burruss
    i dont understand the trouble im having but im gunna fix it
Lg lp1213gxr spitting water how can I fix
Check the AC units condensation drain, it is likely plugged. When an AC is running it dehumidifies the air as it passes through the evaporator core, this creates a lot of liquid water, it must be drained off.
Jul 10, 2016 | LG Heating & Cooling
Water coming out of lg ac
Your unit will have an external vented drain, check to make sure this is not blocked with fluff or dirt as this will cause your issue.
Mar 04, 2012 | LG LSC121PMA Split System Air Conditioner
While running airconditioner water spits out with cold air. Does not happen with heat.
It could because the condensate pan is not draining and when on AC, the blower is faster. Try running the heat on high fan. take a shop vac and attach it to the end of the condensate drain to remove any debris stuck in drain line.
Apr 02, 2011 | LG Heating & Cooling
My goldstar window air conditioner keeps spitting water out of the vents and making a loud noise, what is it? Please.
Hello
Could be the drain hole is clogged up outside.
Its usually located on the bottom r h side.Needs to be unclogged.Use a thin piece of wire or compressed air or even a good blast of water to fix it.
Aug 30, 2010 | LG Goldstar GWHD5000 wall/window Air...
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
What
The drain that runs the condensation from the unit is plugged or trapped...the condensation then blows out the front...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 19, 2010 | LG Heating & Cooling
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Troubleshooting
first I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
Aug 23, 2007 | LG LB8000ER Air Conditioner
Heating & Cooling Logo
1,503 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
