Question about HP PSC 2410 All-In-One InkJet Printer
The power went out and the printer is now making a clicking noise and the power light is flashing. It will not print
  • lrpritsch May 27, 2010
    Yes. Thank you.
    Yes. Thank you.
  • 2,069 Answers
This usually occurs when the unit is plugged into a surge protector.Unplug the unit from the surge protector and plug directly into the wall power socket. If problem persists, post again.
regards
Posted on May 27, 2010
  • Muzahura Frank May 27, 2010
    If the above doesn't get you up and running, then Push the "cancel" button down before you turn on the printer and hold it
    down until after you turn on the printer and the start up sequence is
    completed.
    Regards
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
WHEN PRINTING PHOTOS LINES APPEAR
Hi, It is unfortunate that you are having this difficulty with your printer. One of the best solution that we can give to you is run a series of head cleaning. Please try the following steps below to clean the print head in most effective way:
1) Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3) Click on START.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink, your printer will require service.
Tirzo
Jun 13, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printer
One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START. Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
Jun 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Problem printing
3) Click on START.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
3) Click on START.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Dark red prints with lines throught the picture
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
try this:
3) Click on START.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
