Question about Yamaha CM500 Headset
Hooked up to yamaha mlc 100 but can't use
My cm500's are hooked up to my yamaha mlc 100 but the microphones are not working at all even though they are advertised to be compatible with any product???
Need a replacment Carafe for a Gevalia CM500 Coffee Maker
www.ebay.com
In the EBay Search box, paste in: Carafe for a Gevalia CM500 Coffee Maker
You'll find several for sale
Mar 30, 2017 | Coffee Makers & Espresso Machines
Sennheiser ew 100 g2 handheld microphone loose coil in capsule?
I had a similar problem with a sure sm 57 that I used on a guitar amp. I don't know if this is the correct fix but it worked for me. I took thin strips of paper to use as spacers and placed them evenly around the coil. I used a hot melt glue gun and placed 3 small drops around the edge of the coil. Remove the spacers and the coil should be secure.
Joey Clay
Oct 24, 2009 | Sennheiser Evolution G2 100 Series UHF...
My microphone is not recognised by my acer laptop
just use 5 setp your problem is solve 100%
ok
  1. click stat
  2. click All program
  3. click accessories
  4. click system tools
  5. click system Restore
and select to restor point and select the date form your problem data 1 day befor
Mar 26, 2009 | Computers & Internet
Yamaha Keyboard Microphone Not Working
Hi Simon. Has the cable to your Mike been trapped under the stand, trodden on etc. Could be a faulty plug or even Mike/switch. Did the Mike ever crackle under use?
Have you another Mike and lead to try?
Sorry for the obvious questions but I have seen this happen before and it was a faulty lead...
Dec 18, 2008 | Yamaha Full-Size Keyboard
I have behringer xenyx802 Iam urgently looking to buy a wireless headphone and mic for my mixer and skype which I use for podcasting. The headet must be padded both ears and mic over mouth due to me being...
Here is a link to what your looking for,
http://pro-audio.musiciansfriend.com/product/Yamaha-CM500-Headset-with-BuiltIn-Microphone?sku=245012
I can't tell from the add but hopefully it comes with adapters for both plugs that will work on your mixer. It does have the one for the headphones but the one for the mic is not clear, they are not interchangeable.
You would obviously plug the headphones into the headphone jack. The knob labeled "Phones/Control Room" will control the volume without changing what's being broadcast. What you hear in you phones is exactly what you are broadcasting.
The microphone needs to go into either mono channel 1 or 2. The adapter for it needs to be a mono Tip/Sleeve adapter as the more common stereo Tip/Ring/Sleeve adapter may cause some problems. You can tell the difference by looking at how many sections are on the plug divided by a little black line. Two sections is mono, three is stereo.
Adjust you microphone level by setting the volume knob, the one on the very bottom, to the 12 o'clock position. Then turn the gain knob, the smaller plastic one on the very top, until the desired volume is reached. If you experience any clipping or distortion turn the gain knob down until it goes away. These are general settings, you may want to experiment until you get the best level without noise.
Nov 30, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Rock band
do ya have an eye toy because they have a mic
Jan 19, 2008 | Sony PlayStation 2 Slimline Console
Radio Communications Logo
94 people viewed this question
Top Yamaha Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Yamaha Radio Communication Expert? Answer questions, earn points and help others
