Question about HP ProLiant ML370 G4 Server
HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
HOW CAN I CANNECT HP ProLiant ML370 SERVER HARD DRIVER TO MY PC
WHICH CABLE I WANT USE
  • 596 Answers
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
Posted on May 28, 2010
Issue with power button in HP ProLiant ML370 G6 server
If i am not mistaken I belive that there are two power supplies, correct? what if you swap them? Or if you have a spare... I think that maybe either the button isn't working correctly or the power supply might have some issues...I also think there might be some LED lights on the power supplies themselves...check it out.
Jan 02, 2014 | HP ProLiant ML370 G6 Server
Issue with power button of HP ProLiant ML370 G6 server.
I would check the the power supply to make sure they are seated correctly. Also, if you have intalled any new item, check to make sure it is seated correctly. If all are correct, you may have a faulty power supply or the en power outlet may not be correct specs for power needed.
Good luck.
Frank, N.I.T.
We have hp server ml370 when i restart the server its stopped on attempting boot from hard drive c and never continue
This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
Oct 21, 2012 | HP ProLiant ML370 G4 Server
I need driver of hp proliant ML370 G6
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/swdHome/?cc=us&cc=us&lang=en&lang=en&sp4ts.oid=3884311&ac.admitted=1399271691587.876444892.199480143
May 25, 2012 | HP ProLiant ML370 G6 Server
Compaq ProLiant ML370 G4 (374490421) Server - Windows xp issues
Servers need the Drivers for the Drive array card.
The server should have come with a smartStart CD that has the drivers for it.
You are NOT going to get another OS on this machine unless you load the drivers for the adapter.
... and why put XP on a Server? that's not the optimal OS for the hardware.
Dec 12, 2011 | Compaq ProLiant ML370 G4 (374490421)...
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
I have a HP Proliant ML370 G3 server which was replaced can it be rebuilt for 64Bit Windows 2008 operation?
generation 3 servers do not support windows server 2008 there are no drivers for this OS
i include the OS Matrix for you to confirm
Oct 04, 2010 | HP Compaq ProLiant ML370 G3 Server
HP ProLiant ML370 G4 Server Logo
177 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
