Question about Boating
I have a mercury outboard 50hp engine that will not start
I have a mercury outboard 50hp engine that will not start. The starter engages the flywheel but the the flywheel does not move.
  • 5,537 Answers
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
Posted on May 27, 2010
  • Gordon Richard MacLean Jul 22, 2014
    Leave Ignition In Off Position ,Pull The Kill Switch Lanyard Out.
    Try Turning Fly wheet by hand If It Turns By Hand ,]
Power trim on. Throttle will only raise the engine up not down, 50hp mercury outboard. Works manually on engine.
I recommend looking at swapping the solenoid. It's not that expensive to do. There is one for up and one for down. Sometimes you can bang on them with a screwdriver and it will work again and get unstuck, but still would replace even if you get it working. Cheap fix. Usually 3 wires.
Jul 12, 2017 | Mercury Boating
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
I have a 1986 mercury outboard motor, thunderbolt ignition, 50HP, 4 cylinder. Forward gear works great. Reverse gear works very slowly , moves boat very slow and weak. Appreciate any help.TY
there is no gear box as such in an outboard leg it is just a clutch dog that is slid from front to rear to engage the cogs attached to the prop shaft
the related gear forward or reverse is attached to the shaft with a drive pin or splines
you will have to pull the unit apart to find what section has failed as it appears that the cog on the shaft is slipping ( sheared pin or failed splines in cog)
Mar 28, 2017 | Mercury Boating
I need step by step procedures on how to check compression on a 2004 Mercury 50hp 4 stroke efi outboard motor
Go to a repair service and ask them to check it scanning the computer of your car.
Nov 08, 2015 | Boating
50hp blue band mercury .crack in plate port side leaking water
if its got about 18 bolts on it and aprox 12by6 inch in size then thats the exhaust plate !
remove all bolts and remove plate and then a s/steel plate , check for corrosion and damage etc ! clean all gasket faces and replace gaskets and put a light film of gasket glue on all areas where gaskets touch and refit !
Feb 28, 2015 | Boating
50hp blueband seized
make sure its not the gearbox ! drop the box and try the engine again ! ive had this b4 !! when you used it last there was plenty of power and cooling ? easy to strip if it is seized ! please let me know more !
Feb 18, 2014 | Seloc Mercury Outboard Engine Repair...
50hp mercury marine outboard
put a water pump kit in it
May 26, 2013 | Boating
Smoke coming out of bottom carb on mercury 50hp outboard engine
It's possible that a little fuel vapour come out of a carb on an hot engine that has just stopped.
Does the motor starts again and runs well in higher rpm ranges? Is the stall only when idling? If so, enrich the idle fuel mix ( screw out the idle mix screws half a turn t a time )
Aug 06, 2017 | Boating
Honda outboard engine 50hp nrepair manual
Here is a link to clymer manual. honda won't allow free manuals posted online. you will need to purchase. click here
Oct 25, 2009 | Boating
MERCURY OUTBOARD 50HP 1974 NO SPARK
Clean or replace and set points to .020. Also replace your condenser.
Mar 18, 2009 | Boating
Boating Logo
596 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
