Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Display or power issues with an SVA LCD #7005L screen.
Short story short, I went to throw the trash out and I found this silver LCD screen in the dumpster but I couldn't the original power supply (DC 12v; 40w max consumption) that it came with. I managed hook up the white DC 12v cable that feeds from my PC speakers to my monitor (for power) to the SVA LCD screen and it turns on.
When turned on without the vga cable it displays the ''no signal'' message and the power button turns red (green when ok). Now, when I turn on the LCD screen with the vga cable it just starts turning on and off continuously and I just had to unplug the power cable.
I took the LCD screen apart and I checked on the main board for the vga and dc jack soldering joints and none were broken. Also, I didn't see any burnt capacitors of spots on either board. I have a soldering iron but I'm amateur at electronic stuff.
So what's the deal? Thanks.
    President:
  • 1,138 Answers
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
Posted on May 27, 2010
My monitor has power but the screen does not have a display no matter what control buttons I push
When i plugged in my sva lcd monitor it was all black but the green light was on,so i reached around the back and tightened up my cords and it came on :)
Jan 14, 2012 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor sleep
it is because there is no supply to the processor!!
u should try removing and reconnecting the SMPS of your PC which is in the CPU!!
it is mainly because of the smps's loose connecting or a short on the board or in some device connected to the board!!
reply and rate!
Jul 10, 2010 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
I have a sva VR-17S monitor and i am trying to use this for my other computer and i need to download the software. where can I find it ?
Normally you don't need a driver for a monitor, any screen resolution adjustments is done by the Control Panel - Display - Settings.
Sep 08, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Faulty backlights
try and trace the 5v or 12v regulator going to the backlights.Check whether it's faulty.You should also try to hot air the whole area icase of dry joints.Hope have assisted.
Aug 20, 2008 | Computers & Internet
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
352 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
