Question about Car Audio & Video
I need to know how to install my equalizer to my head unit. and i have a amp to i need to know how to wire it. in detail. and rca what port do i put them in. im equalizer has sub rear front and cd ports. my unit is a newwer kenwood in the back it has front back sub and aux ports. my amp is two channeled but i bridge them for my ki=enwood 10 inch box i need detail step to step directoins
  • 5,807 Answers
Hi
rainamorales,
Basically all you need to do is connect the audio out of your
unit ( source ) to the " Input " of your Equalizer ,
and " out " to a separate amplifier
You cannot route back the audio out of the source to the Source.
Meaning out of the source to the input of equalizer and out of the
equalizer to the input of a separate Amplifier.
Although there are instances , that connecting the equalizer won't
work , due to grounding systems.
If these is your case , you may need additional " line out converter "
to finish the job.
try to have the amp working first.
then connect the equalizer.
Be attentive on these settings, if your amp wont power up
then do not proceed to the next step.
Have your amp and equalizer working before connecting the " Source ".
Working meaning you can use an MP3 player or an IPod to check ,
if audio is OK , same with the power.
If it does, then connect the " Source ".
You may be having problem connecting the Equalizer due to
mismatched input of Amp and output of the Equalizer.
To be sure it will work ( equalizer ) have your Source connected
direct to your amp.Verify if it can work properly.
Any output of the equalizer will do ( RCA in particular ).
Posted on May 27, 2010
How hook amp up to a oem integration SNI-15 line output convertor
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
Apr 23, 2014 | Car Audio & Video
Another conundrum
To check for yourself, get an Ohmmeter and see if the outers of the amplifiers RCAs are connected to the ground or each other. If so then it cannot take speaker signals directly.
I suspect the 'High Level' the manual speaks of are the 4volt auxilliary audio signals that can be found on some newer head units, not speaker signals.
Speaker level signals from a bridge amp CAN be used on grounded RCA inputs if the signal is first passed through a simple decoupler and attenuator.
Diagram to explain....
Nov 22, 2007 | Infinity 475A Car Audio Amplifier
Im having problems installing my equallizer i have it hooked up to a amp. do i put the jacks to the 4 inputs or the 2 outsput jacks
Hi, the equalizer input is from the head unit preamp outputs and the equalizer output goes to the input jacks of the amp. There should be only 2 channels in and 2 (or sometimes 4) out of the equalizer. If you need more help, please provide model numbers of the head unit, equalizer, and amplifier and tell me all of the speakers you are trying to hook up.
Mar 26, 2011 | Car Audio & Video
I have a 2007 galnt and i cant instal my amp on my factory radio i have the rca adapter wat can i do?im a bout to give up on it and i dont wat to put a aftermarket radio becouse the factry radio looks nice
you need to get the adapter from best buy for about 20 bucks... then find the correct wire code for you head unit and splice into these wires with the "RCA line out adapter" i will be happy to assist you more if you can provide more detail
Mar 21, 2010 | Stingpro ST444 1850 Watts Complete...
Need a diagram for 2009 head unit wires to install after market amp to stock head unit.
you need a rca adapter to t-tap into your speaker wires to hook up your rca wires. Then find a good switch wire to use as an remote wire.
Nov 04, 2009 | Car Audio & Video
How to install car stereo with an amplifier and equalizer
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there hope this helps
Oct 23, 2009 | Pioneer GM-D7400M Car Audio Amplifier
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Only get sound wen rca's r in halfway
You have a bad set of RCA's. Try and get a pair specifically made for car audio. There are hundreds of brands, usually the cheap ones work fine.
What usually happens is on cheap RCA cables, wires inside the actual plug split apart and short out on one another. Get another set of cables and you'll be fine.
Jan 30, 2009 | Alpine MRP-M450 Car Audio Amplifier
I need to install a max385vd in a 2002 pord f-350, do i need an install kit?
Regardless of whether this is an amp or a head unit, an install kit is either very helpful or necessary. If it's an amp, you'll need it for sure - you can't power an amp with 18 gauge factory power wiring like a head unit can use. You need to get at least 10 gauge power and ground wire, 18 gauge remote turn-on wire, and RCA patch cables to conduct the sound. If you have a factory head unit, you'll also need a line-level adapter to give you a source for the RCA patch cables.
If this is a head unit, you'll need the adapter harness to plug your existing stereo harnesses into the new head unit. It makes it simple - the wires on the new head unit are color-coded for what they do, and the adapter harness is identically coded. Match the colors, then plug it in. You may also need an antenna wire adapter (some cars require this).
Aug 10, 2008 | Clarion Car Audio & Video
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
