Question about Whirlpool LGR6611L Gas Dryer
Dryer wont come on. what should i do? my wife was washing, it dried two loads and then it just wouldnt come on after that. i push the start button and get nothing.
    Problem Solver:
  • 18 Answers
1. Does the dryer light come on when you open the door? If so, it's likely the belt is broken. You will need to replace the belt.
2. No dryer light? it's likely then that the thermal fuse is blown. They are located in different places on different dryers. On Maytag and many Whirlpool dryers, it is located under the top, right next to the heating element with two white wires leading to it. You can test the fuse by bypassing it TEMPORARILY. If you connect the two wires together or make a jumper for them, (always shut the dryer circuit breaker off FIRST before attempting this) and the dryer magically comes alive (after you turn the circuit breaker back on) then you know what's wrong. Just changing the fuse is often not enough - you should find out why your dryer overheated. (poor airflow - blocked duct, etc)
Posted on May 27, 2010
Whirlpool duet dryer GEW9200L will turn on but will only "click" when push button in. Timer light starts flashing. Wife was drying a load of towels with her pair of tennis shoes in it on the last load that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Dryers
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Dryer won't turn on
touch the door swich and see if it clicks when you push in on it,if that is good you'll have to check thermal fuse that is located either on blower wheel housing or in back of dryer,check to see if belt broke some dryers have switch that kills dryer if belt breaks
Nov 03, 2009 | Kenmore 73932 Gas Dryer
Dryer won't start
Could be a blown fuse.Check out repair manuals and more pix HERE The fuse looks this:
Sep 01, 2009 | Dryers
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool LGR6611L Gas Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
