Question about Samsung M200 Black OEM GSM Unlocked Cell Phone
I hv Samsung M-200 and it is water Demaged and in a dead condition so what i do?
  • 180 Answers
Remove the batteries leave it to dry. dont even try to switch it on for 2 days atleast. when you leave it to dry make sure that you are not exposing it to a very high temperature. After it is completely dry use a vacuum cleaner to **** all the remaining moisture, please do not use a blower as it will only send the eater droplets at a further unreachable corner. After doing this try and switch on your phone charge if necessary. do the above to procedures ASAP and give it to a repairing shop if necessary, the sooner the better
Posted on May 27, 2010
No display in samsung UA46D7000 3d led tv
it is not enough info but i think you did not have buack light one of the led blocks is demaged
Mar 08, 2017 | Samsung Televison & Video
My Bernina 200 bobbin thread snagged and now the bobbin thread will not catch the top thread when I sew, thus, there are no stitches made in the fabric.
1. CHANGE NEEDLE.
2. ADJUST BOBBIN TENSION. MAKE SURE YOU ARE USING THE RIGHT BOBBIN FOR THE MACHINE. THE WRONG ONE WILL NOT ROTATE FREELY. HANG FROM FINGER AND BOB. SHOULD EXTEND ONE INCH WHEN ADJUSTED RIGHT.
3. ADJUST TOP TENSION. (START AT 3)4. EXTEND TWO INCHES OF THREAD FROM BOBBIN. HOLD TOP THREAD TO THE FRONT AND A LITTLE TO THE RIGHT.
5. TURN HAND WHEEL TOWARDS YOU. THE BOTTOM THREAD SHOULD COME UP FROM UNDER THE PLATE.
6. IF THE THREAD DOESN'T FEED FROM THE BOBBIN TO THE TOP OF THE PLATE THE TIMING IS OFF AND WILL NEED TO BE ADJUSTED.
Jan 02, 2015 | Bernina Sewing Machines
Display apperance like two bandas
Graphic card dead or demaged, or not connected properly.
Oct 14, 2012 | Acer eMachines 350-2074 Netbook
Ihave a bp68006844A samsung with like 200 what seem to be dead pixel how hard is to fix it myself
It will be almost impossible to make it right. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 900 posts to different brand TVs now.
Oct 03, 2012 | Samsung Televison & Video
Hi 29 inch Tv having problem of no picture, in dead condition with small ckiking noise.
1) this conditions is lack of raster.
2) test the video detector, flyback, horizontal output transistor, rectifier Hv, see the block diagram
God bless you
Sep 17, 2012 | Televison & Video
I hv samsung duos gt b5722 cell bt it don't connect to my pc i hv cd of samsung kies.installed it sucessfully bt my cell don't connect to my pc. i hv win 7 ultimate 32 bit O.S. give me a solution plz.
hi.
which pc suiet i have to use with my samsung gt b5722 duos.
using reliance netconnect for windom xp prof.
not an expert,so please step by step on my mail if possible
thanks,
rk chhibber
rkchhibber58@gmail.com
Feb 06, 2011 | Samsung B5722 Cell Phone
How to install mig33 beta for samsung SGH E200? i hv download application but i cant run it
i have one sgh e 200 hang problim can tell that what i do it can be good run
Nov 12, 2009 | Samsung E200 Mobile Phone
Bizhub 200 blank pages no error messages
problem in hv unit ( ch corona ) in drum unit replace if necessary
Jul 10, 2009 | Minolta bizhub 200 Copier
Bad service
youcan order the parts from samsung
Nov 19, 2008 | Samsung SP 56 K 3 HV 56" Projection...
Samsung rear projection television HCN4226WX/XAA
Dead Samsung
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Most rookies will not successfully complete the repair and probably do more harm than good.
Sometimes when the convergence chips fail, the TV senses the changed load condition and shuts down.
Unplugging the blue, red or green convergence connector on the convergence board removes the overload condition if the IC is shorted and allows the tv to run, with one color missing.
This is done with the tv unplugged. Then plugged in and turned on to see if it starts. Turn off immediately if you here it start.
Now you know if convergence failure caused the shutdown. You can repair the convergence circuit if that is the problem.
If this has no affect, then you could have a number of different faults in Vertical output, Power Supply or HV circuits that require the expertise of a qualified service person. This would be a bench repair in most shops.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
May 27, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung M200 Black OEM GSM Unlocked Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
