Question about Amana Haier AP125HD Air Conditioner
The Red Exclamation point on my amana ap125hd is flashing. The unit will not turn on or off.
4 Suggested Answers
leobruce
SOURCE: Amana AP125HD Portable Air Conditioner This
I dont have this one, but I searched for problems because I am thinking of buying one. Thanks for info above. This unit has a very high capacity, and a very high electrical load to match. Understandable that it needs full capacity 15 amp service.
Posted on Apr 10, 2009
hvac1960
  • 2133 Answers
SOURCE: I have a Amana portable
Better
Posted on Dec 06, 2010
SOURCE: Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Posted on Feb 18, 2011
Not working. Power on but shows a red flashing exclamation. Doesn't start making coffee.
Did you try to put grease on the brew unit to make it movement easy?
Feb 05, 2016 | Saeco Odea Go
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
I am not able turn the unit on
First check the circuit breakers then the outlet that the unit is plugged into.
Good luck,
Marty
Jun 20, 2014 | Amana Haier AP125HD Air Conditioner
Red exclamation point on verizon set top box
How to reset your Set Top Box to fix common problems FiOS TV Residential...
Resetting your Router and Set-Top Box can resolve a variety of issues such as:
  • Missing Interactive Media Guide (IMG) or On Demand menu
  • Unresponsive Set-Top Box
  • DVR recording problems
If you are having any of these issues, you may need to reset your Router and Set-Top Box. Will resetting my Set-Top Box erase the selections I have programmed into my remote?
No, all settings and selections you've entered such as device codes, favorite channels, and recent On Demand selections are saved and available after resetting your Set-Top Box.
Always reset your Router first and then check to see if that resolves the issue. Resetting your router may be all that is needed.
Important note about your router To avoid problems with your FiOS TV service, make sure your router is plugged in and turned on at all times. Even if you are not currently using the Internet, your router still needs be turned on so that FiOS TV can function properly.
To manually reset your router:
  1. Unplug the power cord to your Router for 15 seconds and then plug it back into the electrical outlet.
  2. Wait 30 seconds and then check to see if this resolves the trouble. If you still have the problem, follow the steps below to reset your Set-Top Box.
To manually reset your Set-Top Box:
  1. Unplug the power cord to your Set-Top Box from the electrical outlet for 15 seconds and then plug it back in.
    Note: Don't confuse the power cord that provides electricity to your Set-Top Box with the coaxial cable that is connected to the back of your Set-Top Box. Unplugging the coaxial cable will not reset your Set-Top Box. Since many issues can occur if your coaxial cable is not securely fastened, now would be a good time to check to ensure all connections are securely connected.
  2. Wait for the time to appear on the front of the Set-Top Box, then power it on.
  3. Wait several minutes while the Interactive Media Guide updates.
  4. Check to see if this resolves the trouble. If you still have the problem, your Set-Top Box may need to be re-initialized. Contact the Fiber Solutions Customer Support for further assistance.
I have to reset my Set-Top Box frequently, is this normal?
No, if you routinely have to reset your Set-Top Box more than three times a week, it is likely there is an issue with your Set-Top Box that needs to be resolved. Contact the Fiber Solutions Customer Support for further assistance.
also you can call for tech support at Dial 1-800-VERIZON (1-800-837-4966)
Oct 05, 2012 | Televison & Video
The ! light is flashing and will not turn on
hi simply empty the reservoir located on the bottom back of the machine. this was my first empty and ive owned it for 4 years...simplest solutions to the hardest problems...
Aug 11, 2010 | Amana Haier AP125HD Air Conditioner
My 1 year old Amana portable air conditioner (model AP125HD) is not getting as cold as it should. My attempt at troubleshooting was to reset the unit, check to see that the options are properly set, be...
inside there is a filter attached to the motor. you will have to unscrew and open the unit to clean it off. it will be approximatly 6 to 8 screws to remove. i used a damp cloth to wipe the dust which was as thick as carpet(lol) cuz my unit is 4 years old and after that it is as cold as ever. also refrain from using the inlet hose as it attract more debris to that filter but still use the exhaust. hope this helps
Jun 26, 2010 | Amana Haier AP125HD Air Conditioner
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Amana AP125HD Portable Air Conditioner This unit now seems to randomly shut itself off, beeping 4 or 5 times after doing so. Not on a timer. I can restart it immediately, but will shut off again in an...
My AP125HD had exactly the same symptoms. It did not matter what ac outlet I used where the air conditioner was.
But...THIS PROBLEM STOPPED once I moved the ac cord to an outlet outside of the house. This outlet is on it's own separate circuit breaker and I have no other electrical equipment/appliances on it.
I guess the user manual is correct that this unit should be on a home circuit all by itself!
Jun 02, 2008 | Amana Haier AP125HD Air Conditioner
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
136 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
