Question about Dryers
Converting my kenmore elite dryer from Natural gas to LP
I ordered the kit for this. I s there anything I need to know about the conversion?
  • Anonymous Mar 19, 2014
    I purchased a Kenmore Elite model 110 92824101 setup for LP. I purchased the new NG orphices but can't find manual on how to change back to NG. Please advise
    Novelist:
  • 184 Answers
MOST KITS HAVE AN INSTRUCTION SHEET WITH THEM.
USUALLY, THE ONLY THING YOU WILL HAVE TO DO IS REPLACE THE VENT CAP ON THE REGULATOR WITH A BLOCKING PIN AND REPLACE THE ORPHICE ON THE VALVE. BE SURE YOU CHECK FOR GAS LEAKS AFTER REASSEMBLY. BE CAREFUL NOT TO COME INTO CONTACT WITH THE IGNITOR. IT IS ON THE END OF THE BURNER.
IT DOES NOT BEND AT ALL. IF YOU PUT TOO MUCH PRESSURE ON IT, IT WILL BREAK.
Posted on Apr 08, 2008
Have Kenmore elite dryer. How do you get into it to convert from LP to natural gas?
most require a kit to change from 1 type gas to the other . they have to come in thru the back someplace
Feb 09, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
I am looking to convert my kenmore 970-c92062 ng dryer to lp.
The supplier of the LP gas can supply the needed parts for conversion.
Aug 09, 2017 | Amana Dryers
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Mar 02, 2010 | Kenmore Dryers
I have Natural gas and am moving where it will be hooked up to lP instead. What do I need to convert to LP from Natural Gas
you will need an L.P. conversion kit. the kit contains a small spring, a new brass orifice and a new brass cap that fits on the gas valve. some kits are minus the spring. you will most likely have to remove the burner to put the new orifice in. any appliance repair store will be able to order you the kit. have model and serial number handy. good luck with your move into the country.
Oct 20, 2009 | Kenmore Elite HE4 Electric Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Dryers Logo
350 people viewed this question
Top Dryers Experts
