Question about Dishwashers
Maytag Mod. MDB4050AWW
Turns on normally then a few
minutes later seem to not work, but
you can hear the "timer" clicking.
  • 901 Answers
Check inlet water flow. Clean the strainer located near the hose end on the machine.
Check the water pump and it's electrical connections.
Posted on May 27, 2010
We have had a 59422 side by side model for just over a year. The water filtration indicator light turned red a couple of days ago. We removed the filter to get the model number and then returned the same...
I dont believe that one event is connected to the other. Sorry to say, but the defrosted freezer is a separate mechanical function. The water filter is not electrical and the red light that comes on, does so by a timer. Once you installed the new filter you must reset the timer for the light to go out. The preset timer then starts counting down. The freezer could be a couple things such as a compressor gone bad, a bad seal around the door (not likely) and maybe the defroster PC Board has the defroster heater stuck in the on position. A local service tech would be best to narrow down the solution.
Jul 14, 2011 | Kenmore Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Maytag Performa Bottom Freezer, Compressor buzzing.
compressor pulling locked rotor. what your hearing is your current relay energizing. compressor goes off on internal overload protection and then tries to restart a few minutes later. unfortunately compressor needs to be replaced. sometimes a hard start relay will free rotor up. it can be purchased at a refrigeration supply house.
Jan 23, 2010 | Refrigerators
My maytag mod #mvwc6esww1 [bought refurbished
Yes, this is a normal function, the washer is actually figuring out the best way to wash the clothes.
Nov 25, 2009 | Maytag Washing Machines
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
May 27, 2008 | Maytag Dependable Care LAT9706
Maytag washer/dryer lsg7806aae
The easiest way i can tell you if it is an ignitor problem or a thermal fuse or something else is to turn the timer  to the timed section past 10-20 minutes then slowly turn the time back while the machine is running once you hit the last 5 minutes you should hear a click at the timer and at the gas valve. If you only hear a click at the  timer and not at the gas valve it is probably a thermal fuse and control thermastat. If you hear a loud click at the gas valve it could be a bad ignitor .If you see an orange glow but no heat or intermitant heat the coils on the gas valve may be at fault
Oct 10, 2007 | Maytag LSE7806A Top Load Stacked...
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
