Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher won't fill with water
Dishwasher wont pump water through the lines. water goes to the unit but will not pump into the washer. checked the timer and it moves manually just fine. had a draining problem a few months ago but its been working fine otherwise.
  • 901 Answers
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
Posted on May 27, 2010
Bosch SHE44C06UC/22 won't fill with water even though you hear water running somewhere.
Check to make sure there is no residual water underneath the unit, they have a flood sensor and if it is picking up water in the motor area it won;t run.
Jan 24, 2014 | Dishwashers
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
MACHINE WONT FILL WITH WATERAND THE WATERCHECH LIGHTS UP
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left. Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Feb 20, 2013 | Bosch Dishwashers
My neff dishwasher is not filling with water
Hello
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Neff Dishwashers
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Water into washer
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 05, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Dish washer won't wash
is the drain hose to low causing the dishwasher to fill and drain at the same time,if the water level is to low the motor wont wash the soap out of the dispenser.hope this helps
Mar 03, 2008 | Frigidaire FDBB1940D Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
404 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
