Question about Carrier Air Purifiers
I have a Carrier Weather Maker SX with a Carrier Electronic Air Cleaner that has no power fuse is good. However there is some discoloration on the circit card. there are several numbers on the card 11325-003 Rev 0 , osi 94v0 , LR 79426 CS2095A1 and HT65AZ120A. so here is the question can I just replace the card does anyone just sell the card. thanks Jason Mooney
4 Suggested Answers
liteswink
  • 99 Answers
SOURCE: I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Posted on May 25, 2010
liteswink
  • 99 Answers
SOURCE: I'm looking for a replacement pre-filter for an
The model number of the pre-filter 203369. You can also call them at 508- 226-7220
Please check this link: Bel-Aire
Posted on Jun 15, 2010
ginko
  • 19396 Answers
SOURCE: I have a GE Electronic
Hi.
I could not track the appliance. I assume that we are talking about an electric air purifier. In that case if there is no power at all check:
Fuse in power cord.
On ~Off switch (test with power off and multimeter on Ohms).
PSU (even if it looks good it may be defective-this must be tested by a trained tech-testing involves reading volts out and testing single components).
If this instead is a gas appliance, test the igniter (it is probably a spark module). The igniter is tested by energizing it and reading if there is DC in to the part. If you have two appliances of same kind, then you can simply swap the igniters.
To source the part you can find a GE appliances part seller, and provide them with the full model number, as from service tag on the appliance. Alternatively contact the GE support number listed in the owners manuals and order the part directly from GE.
Posted on Jan 14, 2011
Loose Fins on Electronic Air Cleaner Cell
I would use hot melt glue to hold everything in place. The air cleaner works by charging the air particle at the front and there is high voltage on the plates. The polarity of the plate alternates where the first plate is positive, the second is negative, the third is positive, forth is negative, etc .
With first wire in front charging the dust particle, the plate attract the charged dust particle to the plate to capture it.
Jan 14, 2014 | Honeywell (F50F1032) Air Purifier
Carrier 58MVC100 furnace no power. Tree fell on main power line and after power restored noting going on with furnace/air handler. LED is not lit. 3amp fuse appears to be good and there is a sulphur smell...
Possible that when power got restored you furnace might have gotten surged. replace fuse any way to be sure. Check break box for trip circuit. Call a tech from there man.
Aug 08, 2013 | Carrier Infinity 58mvc080 Gas Furnace 80k...
Furnace stop working after cleaning the electronic air cleaner F50
Try this educational video: https://www.youtube.com/watch?v=erpnfKbqmoM It could be something as simple as a pressure switch.
I hope I helped you out!
Apr 01, 2017 | Honeywell (F50F1032) Air Purifier
My Honeywell Type No. F50A Electronic Air Cleaner arced continuously even though I had cleaned it a few days prior. I shut the unit off and removed the air cleaner cells. Is it safe to run the furnace...
Yes you can run the furnace with out the electronic air cleaner for awhile.... It you are in a very dusty conditions than I would not run it very long a day or two....because you will not have any protection for dirty getting stuck on the evaporator coil or if you have a 90% gas furnace the secondary heat exchanger...and restricting air flow.... You can put in a 1" pleated air filter the same size as the total of the two cells in place of the cells till you can get the electronic working..... Sounds like either something big is caught across the cell plate or they are still wet and have not dryed out completely. Hope this helps.
Mar 02, 2011 | Honeywell (F50F1032) Air Purifier
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Air Purifiers Logo
109 people viewed this question
Top Carrier Air Purifiers Experts
Are you a Carrier Air Purifier Expert? Answer questions, earn points and help others
