Question about HP Digital Projector sb21 Multimedia Projector
HP sb21 lamp
Installed a new lamp, lamp does not start up. reinstalled the old lamp and got the same effect. prior to all of this the old lamp was working !!! do you know any one that repairs these units. Thanks in advance, DDiaz
There is a very picky sensor on the lamp cover. When the lamp and cover are seated perfectly, your lamp will start.
Posted on Feb 06, 2009
  • Chris Hooper Sep 08, 2012
    How do I find the sensor and ensure it is engaged? I have the same problem with two projectors, after numerous lamp change attempts with a number of new bulbs. They can't all be duds.
    Additional info: The projector acts like it is going to work. The blue light around the on switch is illuminated.the fan runs, and about a minute later, the defective lamp indicator illuminates.
I replaced the lamp in my sb21, but now the right side of the projection is dark. left side is clear and sharp but starts to go dark about midway across. Could the new bulb just need to be cleaned?
Try taking the lamp out and reinstalling it - it may not be all the way in. If this does not help, a polarizer or filter may be bad. It's going to be hard to get replacement parts for this old projector that is at least 11 years old.
The only other thing I can think of is to try a factory reset - look through the menus until you find this.
Sep 29, 2016 | HP Digital Projector sb21 Multimedia...
Hp sb21 out of sync
Are you simply feeding the projector with a video signal outside the range the projector can accept? For instance, trying to feed HD video to a projector that is not capable of high resolution can produce an out of sync image - or nothing at all.
I assume you've tried using a different video cable to connect to the projector, just in case there is a broken core in the original one that carried the sync signal?
Apr 05, 2014 | HP SB21 Multimedia Projector
My HP Photosmart C5180 no longer scans to my Mac OSX 10.6.8
For a worst case scenario you may have to reinstall your Operating System. But try installing Auslogics BoostSpeed and running the diagnostics. Have you installed anything prior to the problem? Sometimes new software can corrupt old system files when you install. Try uninstalling the last software you installed. Hope this helps.
Feb 04, 2013 | HP Photosmart C5180 All-In-One InkJet...
Windows xp will not install my hp officejet 7310 all-in-one printer after i uninstallit? i keep getting a 1603 error or can't remove the old webreg?
If problems arise while installing or uninstalling the software, download this removal utility to uninstall the HP All-in-One software before attempting software reinstallation. IMPORTANT NOTE:
This utility removes only version 4.2.0 of the driver.
Running the removal utility may remove the drivers and software for other HP printing, scanning or digital imaging products.
This utility works in stages. The first time the utility is used, it runs at level one. The next time the utility is used, it runs at level two. There are four levels. The effects of each level are shown in the table below.
Uninstaller level Description 1 Removes the Windows device discovery (Plug and Play) entries from the Windows registry. After running level 1, connect the USB cable to the all-in-one and let Windows try to discover the device again. 2 Performs Level 1 and removes the software drivers. After running level 2, run the all-in-one installer and use the "Add a new device" option to attempt to reinstall the all-in-one again. 3 Performs Levels 1 and 2 and removes the HP Photo and Imaging software. You must completely reinstall the all-in-one software after running level 3. 4 Performs Levels 1, 2 and 3, and removes HP Software Update. You must completely reinstall the all-in-one software after running level 4. Installation instructions:
  1. Click the Download now button.
  2. When prompted, choose Open or Run to start the download and run the installer.
  3. Follow the onscreen instructions.
Details and specifications File name: s.gif gr_uninst.exe [1/1, 866.52k] Released: s.gif 2005-01-11 Version: s.gif 4.2.1 Compatibility: s.gif Microsoft Windows XP, Microsoft Windows 2000
Dec 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How can i know the projector lamp age
go to the menu , check information or lamp timer . u will get the lamp hours.
u can also physically check the lamp for melted filament, white deposit on reflector of broken filament to confirm
Feb 08, 2009 | HP Digital Projector sb21 Multimedia...
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
Jun 13, 2008 | HP Digital Projector sb21 Multimedia...
Ghost images!
I had the same problem, reset the lamp hours by pressing 'menu, 619 , menu" and browsing until I found the setting, but then I also saw an option to test the lamp.  The TV shut off when I tried this and 2 red lights indicating a new lamp is needed came on instead.  It's probably the ballast and not the lamp, but I don't know that I want to put any more money into this set.  I have only had it 2 years.
Apr 26, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
HP Digital Projector sb21 Multimedia Projector Logo
377 people viewed this question
Ben Johnson
