I have a Mitsubishi TV Model VS-60805, HD1080 series made in January 2000. The picture is very red and I spoke with Mitsubishi and I went through the "conversion" (I think that is what it is called). Anyway it didn't work and the representative said I need to take it in to get it fixed. Can I fix this at home?
    Guru:
  • 374 Answers
Sounds like they think it is the board that converts the picture. You could replace some parts but it could be tricky. How is your tech level??
By the way, are all the inputs the same?? any change when you switch to any other video inputs??
Posted on May 28, 2010
  • jeanene20 May 29, 2010
    Hi tthekraut,
    What an excellent idea putting a different video supplier. I connected both a VCR and DVD player and the DVD player had more of a red hugh and the VCR had more of a light green and yellow hugh. I am not so good with Tech stuff but my mind is like a sponge I want to learn and be proud that I did something by myself. Thank you for your time.
    Jeanene
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi Big Screen TV VS 5043
depending on the model it could be serveral things. it could be convergence ic's gone bad or a problem with the power supply, something is shuting it down . contact mitsubishi for your nearest sevicer
Oct 19, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
