Samsung projection tv sp-50l7hx tv keeps blowing the fuse when you turn it on
  • 552 Answers
You have a short in it and need to locate the short first.
If you are not familiar with tv's it would be best to call a service man.
Most of the time the problems inside of the tv are not user serviceable.
Try uplugging the tv and looking inside to check for anything abvious like water damage or leakage from a component.
Be careful not to get a shock!
even if you think there is no danger wear gloves.
Let me know what you see.
Thanks
Posted on Apr 07, 2008
  • 19,396 Answers
Replace the power unit.
  • Ginko
    Ginko Apr 07, 2008
    Check first that is not a problem with the power socket. Plug it into a different socket.
    Then check the tv power cable and the plug for an eventual short, eventually you may need replacing the cable.
    If is not the above then there is short inside the tv, near to the power supply, probably in this case you will need to replace the power unit.
    Regards
Troubleshooting samsung tv
If picture is OK, there should be sound too. Check the audio settings. Refer its user manual. If audio settings are OK, check its speaker first. If it too found OK, check and replace the audio output card. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 11, 2013 | Samsung SP-50L7HX OEM TV Lamp
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
Samsung rear projection tv sp 50l7hx keeps turning off and on every fue minutes
This could be a lamp, color wheel or one of the fans.
www.richmondtvservice.com
Apr 11, 2012 | Samsung SP50L7H 50" HDTV-Ready Television
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
SAMGSUNG REAR PROJECTION TV SP-50L7HX
check for the power supply especially the capacitors
Mar 16, 2009 | Samsung HLN5065W 50" Rear Projection...
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Replaced fuses & they keep blowing
there could be a shortage in any of the dc line that cause the fuse to blow up again, either overloading or chortage will cause this, try to see for any sign of other componenet failure, wires that has been bended and cripped, transistor that has been twisted or alike
cheers
Sep 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
