Question about Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle
When i break the barrel it doesent catch.
Had the gun for a few months. when i used it it was great. one day it stopped working. when a break the barrel it wont catch. it just bends back and does not load.
how can i fix the problem.
Eddie
  • 86 Answers
Try to clean the barrel and make sure there is not an object jamming the spring.
Posted on May 30, 2010
My granddaughters 760 pump master will not hold air pressure. When you pump the handle it makes a funny noise such as rubbing the side of a ballon filled with air. The BB just falls out of the barrell. Can...
Hello, I'm not sure why you wrote under this other guns listing. The Crosman Phantom .177 Caliber Break Barrel Air Rifle is a single break action pump and it only shoots Pellets. also much nicer than the 760 pump master, but, it also costs more than 2x's as much.
as for your problem with the 760. sounds to me like it was not maintained well. If You have tried this already ( Crosman Pellgunoil® Air Gun Lubricating Oil ) and it did not work. You can assume that little BB gun is probably broken, the air compression chamber have popped a seal most likely.
if You haven't tried that, oiling the gun then I suggest doing that and maybe it's not too late. There really isn't a lot to be done on these cheaper models of BB guns.
if the BB gun is not years old, just purchased, and Amazon buy, or something else cool like you have a wal mart receipt for it or even if you don't have a receipt and you just want to exchange it. ( i will explain that in a minute ) then I suggest you try sending it back.
If You bought it at a store`, you don't have a receipt. do this if you feel you did nothing to deserve this broken gun.
go back to that store and buy another one, exactly like that one. with cash or card. save your receipt, take the gun home, get it out of the package and use it and take care of it according to the directions. in a day or two take the broken one and the box from the new one back to the store and tell them you want a refund and they will credit your card back Or if you paid cash they will give your cash back. This method of return eliminates the possible bad mood or cranky manager that COULD turn your request down because of no receipt.
This is a great answer to your problem isn't it? :O) Hope it helps.
Mar 09, 2015 | Crosman Phantom .177 Caliber Break Barrel...
Pellets jammed in the gun's barrel
The best way I found to fix this is to break the gun down. Once you've done that you can slide the barrel out and use a push rod to remove jammed pellets. To stop this issue, I've read to not use short skirted or pointed pellet.
Jan 02, 2014 | Gamo Pt-85 Blowback
How do you caulk the gun brand new, never used before. lost manual
This gun is a break barrel or break action gun. Hold the stock in your left hand and pull down on the barrel with your right. Once the barrel is down you feed your pellet right into the chamber. Pull back up to set the barrel ready to fire.
Jan 01, 2011 | Crosman ® Phantom .177 Pellet Rifle with...
I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
Oct 25, 2010 | Crosman Optics
The weller 8200n does notheat up
Make sure the tip is tightened fully, use a 5/16 wrench to snug it down.
Feb 28, 2010 | Weller 8200 Soldering Gun
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle Logo
248 people viewed this question
Top Crosman Boating Experts
Ted Maxwell
Neil
Level 1 Expert
yobo007
yobo007
Are you a Crosman Boating Expert? Answer questions, earn points and help others
