Question about Microsoft Xbox 360 Elite Console
When connect the hdmi cable unsopported singnel error comes
I connected the hdmi cable correctly but when connected sounds are there but cant see the screen its black
  • 30 Answers
Reset the video settings on your Xbox. SInce you put a HDMI cable, the settings are still set to what they previously were, and they need to be changed.
Posted on May 27, 2010
How do I connect my receiver so that the sound comes from my speakers????
Please read the manual. You should connect speakers to the speaker output of the receiver, or amplifier. You connect the TV with a receiver through a HDMI cable. Depending what would be the source from that you take the output and the place the signal is going to there you should use the input. Don't connect anything without 100% certainty it is correct. You could damage the whole equipment when connected the wrong way around.
Dec 28, 2014 | Samsung 50" Uhd 4K Smart Hdtv
I cant connect my tv to computer
Hello
All modern TV's can be used as computer monitors - you just need the correct cables and select the correct input on the TV.
What cable are you using to connect your PC to your TV? VGA or HDMI? Your listed TV has both ports but your computer may not have a HDMI port. Either way, connect the correct cable from your PC to your TV and note how the port is labeled.
Turn the TV on and then find the "Input Select" button on the remote and press it until the above port appears on the screen.
If you use the VGA port, you will need to hook up the audio from the PC to the "PC/DVI Audio In" port so the sound will play on the TV speakers.
You can find the manual for your TV here:
http://www.sansuiproducts.com/products.html
Hope this helps!
Nov 09, 2013 | Sansui Televison & Video
I cant run my gateway GT5676 pc in normal mode with Samsung TV / Monitor
If I'm understand you correctly you said you have the HDMI Cable and the VGA Cable comming from the Computer to the TV. You should only have one cable. Either use the HDMI from the computer to the HDMI to the TV or use the VGA from the Computer to the VGA on the TV. Once you have the cable connect select your input on the TV. If you have the VGA Cable connected your input to select on the tv will probably be PC or Computer. If you use the HDMI Cable your input to select on the TV will be HDMI.
One you connect the cables and select the input try rebooting the computer and the video might show up automatically on the tv. If not you will have to hit the FN (Function key) + the correct (F1 thru F12) key that corresponds to the external display. The correct key will probably have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct key (F1 thru F12) that toggles the display. The display will toggle on 3 setups (Computer only, TV only, both the TV and Computer).
Now as for not being able to boot up normally that's another issue.
Apr 06, 2012 | Computers & Internet
I cant find the hdmi icon in sounds
Hello walchell,
Welcome, and thank you for using FixYa!
To answer your question: HDMI Audio Output is part of your Digital Output package. Try turning up the Digital Output.If you are not hearing sound to your TV from your PC or DVR while connected to the HDMI cable, it is likely that you have purchased a cheaper HDMI cable that only provides video out. A high quality HDMI cable cost close to $35.00 for both outputs.
Have a great day!
Dec 01, 2011 | Computers & Internet
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
Cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Jan 19, 2009 | Acer Aspire 6920 Notebook PC
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Microsoft Xbox 360 Elite Console Logo
81 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
