Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Gear that fits 776135 input shaft on a tecumseh gearbox
Where can I get one as all the input shafts only show the input by itself and I want the gear that fits on the end what drives the gearbox
  • 3 Answers
Http://www.ebay.com/itm/Tecumseh-Input-Bevel-Pinion-778113-A-OEM-NEW-OD-/140444782520?pt=LH_DefaultDomain_0&hash=item20b3294fb8
Posted on Sep 26, 2012
My ford focus is leaking oil think it might be gearbox oil,
Is the oil you see reasonably clean or is it black. The gearbox oil would be cleaner than the engine oil. Gearbox leaks would most likely come from one of the following:-
  1. Drive shafts
  2. Gear change lever inputs,
  3. Speedo cable
  4. Reverse light switch
  5. Drain plug
  6. Input shaft seal (inside the bell housing).
Pig a piece of paper under the car when you park it at night to give you an idea where the drip is located and inspect the area above that position
Jan 24, 2011 | Ford Focus Cars & Trucks
1st 2nd 3rd gear whining noise but stops in 4th and so on,
this would be an internal bearing inside the gearbox on the input shaft......you have the shft coming in form the engine, and the input shaft houses 1,2, 3rd and 4th gears.....the 5th gear is located on an intermediate shaft.....and then you have the output shaft...now if you had said all gears i would have said output shaft bearing......and if you had said 5th gear only, then this would be the intermedaite gear.....
but you are only saying 1,2 and 3......why its not happening in fourth is that the gear ratios that the shafts turn in correlation to thre gearing changes as you get to 4, like on a 10 speed bicycle but in 4th it is a 1:1 ratio, so no excessive loads on the shafts are noticeable....
This will require a transmission overhaul......
Aug 26, 2010 | Ford Mustang Cars & Trucks
Oil leak from driveshaft n/s
not sure if you can interchange the manual & aut shafts, but you should check to see if there is excessive play where the shaft enters the gear box if so the diff bearings my be worn, if there is no play or noises from gear box when driving, remove the shaft again an try the seal on the shaft to check it's a proper fit, before fitting seals it is a good idea to leave them soaking in oil for a few hours prior to fitting
hope this helps
Regards
Jim
May 29, 2010 | Hyundai Motor S Cars & Trucks
Cannot align clutch plate with gearbox imput shaft on my 1985 r80
you may have the wrong clutch plate try it on the input slines first or its just not centerd right try using a bit of round wood with tape round it to line up the clutch plate first also check that there is no little burrs on the shaft or clutch plate stoping it going in to place and put a smigin of grees on the gear box splines the clutch plate must slide easly on the shaft before you fit it in or the clutch may start sliping on you,
Feb 24, 2010 | 1989 BMW R 80
What is a spleen in a gearbox
in a g/box you have
Input shaft
main shaft
gear cluster shaft
synchros
change levers
change rods
output shaft
all the bearings and seals
Spleen???Strange one?
Is this a mechanic trying to baffle with bull s..t
Hope this helps
Nov 05, 2009 | 1992 Toyota Celica
Gearbox whiney, stops when you put you're foot on the clutch,could it be thust bearing or is there other problems known of.
No your problem is the G/BOX
As when you push the clutch pedal in it stops the centre plate of the clutch which is fitted to the input shaft of g/box, and when clutch pushed in it stops turning, so the g/box stops turning Answer is....
Either the g/box input shaft bearing OR the layshaft (which lays in the bottom of the gearbox ) the beatings on that are worn out and also the shaft will be stuffed.
Sorry to tell you but the box has to come out ,stripped and rebuilt with new layshaft and bearings and any other parts worn,(but the l/shaft or input shaft bearing )have to be replaced ASAP
Let me know how you get on Ron
Sep 27, 2009 | 2001 Mini Cooper
I have a vm80 8hp tecumseh engine 150092D day
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
Sep 25, 2009 | Garden
Hard to get vw golf 1999 into gear
sounds like the clutch needs adjusting or replacing also the spiggot bearing in the cranckshaft where the gearbox input shaft fits may be worn or damaged
or the front bearing on the input shaft is worn & or damaged
Check oil level in the gerabox is ok
Cheers Rob
Aug 16, 2009 | Volkswagen Golf V Vw Red 1:18 Scale...
Ford probe
the front drive axle on one side may have not been installed all the way in to the transmission, check to see if it is loose and have some one look under front end with engine on, front end jacked up, emergency brake on and in gear to see if a axle is turning. if one is and yhe other is not put the car in park and turn\ roll the wheel that was not turning by hand if it rolls your problem is most likley to be the axle has come loose from the transmission
Oct 18, 2008 | 1990 Ford Probe
Kenmore 90 Series Washing Machine
the coupling does go bad, Often, very often
one of the two spiders is attached to the motor shaft, one is attached to the gearbox input shaft and the rubber ring mates them together, the motor shaft coupling collapses often,
the coupling is ~$16-$25 depending on the parts sales place.
If you can see the coupling, you probably already have the body off,
If not remove the body
from there its easy to replace
undo 2 spring clips that hold the pump on the outer of the motor,
pull pump forward and off the motor shaft and swing aside,
remove screw from head of spring clip between motor and gearbox, remove this spring clip (remember position)
swing motor against coupling to loosen other spring clip, remove spring clip
pull motor forward and away from gearbox
break couplings off shaft of motor and gearbox.
  • NOTE: new coupling sets have a metal center hub to combat this very common failure,
    ask the parts supplier if they have one with metal hubs,
    if they offer to sell you one identical to the picture, all plastic, old style
Fit new couplings to motor and gearbox shaft using wooden dowel between the teeth, on the hub centers, hit the dowel, not the gear, with a hammer.
fit new rubber ring to gearbox,
install in reverse order
rotate motor to align the teeth
Aug 03, 2008 | Kenmore 15864/15862 Top Load Washer
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
90 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
