I have a Palm T/X that simply won't turn on at all and does not respond to the reset button. I had no warning of low battery power but I haven't charged it in a few days. I haven't sync'd it with my computer in a long time. What can I do? Have I lost the data if the battery is dead?
    Genius:
  • 3,422 Answers
HI,
Here is the solution to your problem.80% of the time the problem is with the battery.Replacing it usually fixes the problem.And 20% of the time it is the charger.So you can first try replacing the charger to see if it fixes the problem or else the problem is with the battery.
If it is still under warranty just return it to them.They will fix it.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 07, 2008
  • 655 Answers
It sounds your battery is down and thats why its not getting. Loss of battery power does not mean any loss of saved data. Just recharge is and use there might not be any problem.
If any problem occures just Aks me
And please mention your Manufacturer and model no. when asking again.
Thanks
Iqbal
  • 2,326 Answers
If the battery went dead, the data you had there could be gone.
I would suggest to recharge the battery first and do the rest of the setup once the battery is fully charge.
    Master:
  • 555 Answers
Have you tried operating it while it is connected to its cradle?
SOURCE: I get an error message everytime I tr to sync.
I had the same problem. I found that by removing Addit from my Palm and reinstalling Palm OS without the Addit software, it cured the problem. Never had a problem since I removed Addit.
Posted on Apr 02, 2007
futureloginn
  • 734 Answers
SOURCE: How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
Just_Bobz
  • 448 Answers
SOURCE: can I hot sync z22 palm without the touchscreen?
The cable with the synch button is for the e2.
Posted on Jan 01, 2009
supportthe85
  • 35 Answers
SOURCE: Palm 505 - Windows XP Unique Sync Error
Downgrade to 4.0
Posted on Feb 24, 2009
supertex
  • 30 Answers
SOURCE: Palm stuck on the Palm Powered Screen
try syncing it to your computer
Posted on Mar 24, 2009
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Absolutely black screen - will not power up - did not give warning of low battery - palm z22 about 2 years old ---is it dead????
The Z22 suffers from 3 problems. One of these is the Black Screen of Death. I got a used Z22, and over the years discovered this problem. The small battery was a perfect fit of power and size when manufactured, decades ago, but, time alone has deteriorated the capacity, so that a "NEW" , sealed-in-the-box Z22 today, has a weak, dying battery that needs replacing. These are $10 free shipping from China. The BSoD seems to be caused by a dip in power from the battery to the LOGIC CIRCUITS that control the ON/OFF/SLEEP/CHARGE, etc states of the Z22. If the logic gets out of sync, the unit is in an INVALID state, will not charge, nor respond to the LOGIC buttons on the front - these buttons are NOT the standard ON/OFF buttons from the past that mechanically connected or diss-connected power. All the buttons on the Z22 are touch snap disks that are connected to transistors, to flip logic states. THUS, is the power in any of the transistors gets low, the transistor is neither ON nor OFF, and the control circuits are in a messed-up state. Or another way of looking at it, the ON button is a logic gate on a transistor network, and the only way to activate the "ON" logic state, is with full power to the circuits! -- the power on the Z22 is ALWAYS ON. . . The screen may turn off, and the chips may go into "sleep" mode, but the Z22 is always on. SO if there as a weak battery, you may get the random Black Screen of Death. The GOOD news, is the the DATA and programs that you purchased are incredibly SAFE, as long as you do NOT do the HARD RESET (which someone suggested ! (NOT ) ). I have ripped apart the Z22 dozens of times, and subjected it to freezing and heating and all sorts of horrible things, the data has always been 100% reliable, -- stored in permanent memory. There is a quick way to get rid of the BSoD - you have to open the unit and cut one of the two battery wires, wait 2 minutes to kill the logic circuit power, then re-connect. I added a switch on the Z22, just for this purpose. I would recommend, if you get the Z22 re-powered, to get a new battery as soon as possible. This should clear the BSoD for a while. See my tiny website :
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.htm
There are many photographs and step by step procedures to try to get the data off the device, maintain the Z22, get parts, and use the Z22 with the new 64 Bit Windows computers. The BEST way to use the Z22 would be to get an old Widows 32 bit laptop (ie WinXP), and simply connect the Z22 in a standard way using the software that it was designed for... The new patches to 64 bit machines, are very limited, and many previous features do not work.
So the bottom line - all your data, information, and programs are safe. You simply have to reset the LOGIC CIRCUITS (this has nothing to do with the PALM Z22 SOFT and HARD Resets !) - it has to do with disconnecting the power from the battery, or waiting until the battery is COMPLETELY DEAD ! (which can take a long time! )...
Good luck
robindustygraves sept 2014
Z22 PALM PILOT 691d763d-1b45-4323-a389-5dd3900ad65d.jpg 4ab4c25b-c05c-4deb-898e-d858abbab87f.jpg b63d6d62-a28c-4450-b1de-0e692a79ae08.jpg 8387fdcf-76fa-42ab-a7d4-e941d697b879.jpg
Nov 11, 2008 | Computers & Internet
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Jul 06, 2008 | Palm TX Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Palm TX
Hey mike.
First, i have a question,
have you tried to reset it.
if not try it. press the little button at the back using your stylus and check if it will reset.
good luck
Nov 19, 2007 | Palm TX Handheld
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
