Question about RCA P52960 52" Rear Projection Television
My 62 inch big screen looks blurry and 3D like what can I do to fix it?
  • 25 Answers
Have it cleaned and focused! Sorry thats all I can tell ya,but you knew that much ,you were probably looking for some easy trick but there is none.
Posted on May 27, 2010
52 rca bottom left corner words are blurry but fine every where else when you play a video game It almost looks 3d to
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do you fix a 52" hdtv ready when its in 3D blurry format
This tv doesn't have 3D capabilities - the image appears blurry because both images are displayed on the same screen at the same time. Just don't use the 3D option from the BluRay player, view the movie normally - 2D.
Jun 13, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lines, a little blurry, a little movement
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2010 | Hitachi 51F59 51" HDTV Projection...
My kp-51ws-510 looks like 3D! How can I fix this
TV shows that kind of picture when convergence out ICs become defective.
Replace 2 big black convergence ICs on D board in TV, these ICs are mounted on silver heat sink, requires soldering work if you are not comfortable with replacing ICs, call local tv tech.
Let me know if there is any further question.
Thanks.
Nov 17, 2009 | Sony KP-51WS510 51" Rear Projection...
Fixed coolant now picture looks great but cornrs look 3d
You need to replace Both of your convergence ICs they are Big Black ICs will have Part number on them
STK392-150 Call Mats Electronics 1-800-628-1118
Nov 12, 2009 | Philips 46PP9302 46" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Screen showing lots of colors caving in on top
You have no power to your convergence circuit. Depending on what model RCA you have will determine which parts are bad. Will cost about $200-$300 for a repair shop to repair.
Jul 08, 2009 | Televison & Video
62 inch phillips Tv all of a sudden has a double image. The screen is showing the picture it looks as if it's in 3D but every chanel.
Please respond to this same post with the model number of your phillips and I will post what you need to repair the set.
Aug 08, 2008 | Televison & Video
Sony 46 in. big screen picture problems
read this
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
