Question about Maxi Aids Braille Remind-O-Timer
How do I set the 12 hour James remind-o-timer
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
How to set timer
I found a pdf of the manual for your stove. See the link below to download the pdf.
If you press the button that looks like a bell under the clock you can use + an - keys to set the minutes for a reminder timer that won't turn off the oven.
After turning the thermostat to the temp you want and function knob to the setting you want set the cooking time as follows.
You press the button that looks like steam coming off a pan below the clock for 1/2 second .
Then use + an - keys to set the minutes. Every 12 minutes will make a new segment light up on the inside ring so the numbers corospond to hours on the inside ring.
When the time is where you want it, wait 6 to 10 seconds and the cooking and timer will start.
Smeg A42 5 Instruction Manual
Jun 05, 2014 | Smeg A42-5 Dual Fuel (Electric and Gas)...
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Samsung cooltech needs reset to keep cooling
HI.JAMES. shot in the dark.it might work for a quick cheap fix.ok 1-get a 24 hour ac plug in timer.plug fridge into it.set timer to run for 4 hours and off for 10 minutes.it might work.let me know if it does.better then PCBs and sensors etc.good luck.ali
Jun 19, 2012 | Refrigerators
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have the timer set, all 7 cycles to come on at 6am go off at 6pm. set and checked. put mode on auto but light did not come on. it only came on when set on the on mode. please help, thank you
You are having problem programming zilla digital power strip timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Either timer is defective, or programming has conflicts that cause timer to ignore programming, or blue-yellow outlets are not understood, or combination of these problems.
Zilla yellow outlets are for daytime hours.
Blue outlets for nighttime.
The instruction manual does NOT specify what hours are for daytime. 6 am to 6 pm? Or 12 am to 12pm?
The zilla analog timer divides day and night at 12 and 12.
If digital timer is also 12 and 12, then you cannot set ON at 5:59am and OFF at 5:59pm without fudging the current time setting. For example offset current time by exactly 6 hours.
Add a comment for more free help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 10, 2011 | RTO Zilla 24/7 Digital Timer Power Center
Have GE digital timer 15117. Can't figure out how to make the display show AM/PM so I can set it correctly. Clock hour/min just cycles through 12 hours without noting AM or PM setting. Can't program...
GE 15117 manual
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
You might try a new AA battery.
Some guy wrote in this week and said he bought 6 timers and all the batteries were bad except 1.
Some timers, like Woods TD1300, and others have the 12 hour or 24 hour option.
You press and hold Time button to choose 12 hour or 24 hour
But GE 15117 manual says nothing about this option.
GE 15117 timer is same timer as Woods 59403
Several folks have written in past couple weeks about the Woods 59403 timer skipping over functions.
The best I can guess is your timer is malfunctioning like the other people's timers.
Woods 59403 manual is identical to GE manual, and says nothing about 12 hour 24 hour option either
http://waterheatertimer.org/pdf/Woods-59403.pdf
I test timers for programming and wiring difficulties.
Yesterday 3 timers arrived here, and 1 didn't work.
I took it apart and tested the electronics, and something went bad.
When these timers don't work, you get your money back or throw them away.
Dec 04, 2010 | GE Hardware & Accessories
Setting the timer
Click on the link below to download your manual if you see your model listed.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
You can install a photocell for six to ten dollars which you can wire in series with your timer output. The photocell that will bypass the daylight time cycle from 8am-12pm.
Jul 27, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Maxi Aids Braille Remind-O-Timer Logo
413 people viewed this question
Top Maxi Aids Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Maxi Aids Hardware and Accessory Expert? Answer questions, earn points and help others
