Question about True 72 cu. ft. / 2039 liter Commercial Freezer T-72F
Freezer will not cool below 28 degrees . head presure 290 , fans working ,evapurator is not over icing freezer is in 80 degree inviorment
    New Friend:
    Problem Solver:
  • 12 Answers
There are countless reasons why the freezer is not cooling down enough. As the other poster suggested, it doesn't hurt to clean the condenser. Your head pressure is a little high, but there is no way to tell why. These units are notoriously fragile, and they will have problems at the slightest provocation. If clean condensers don't do the trick, try completely thawing the unit out. This seems to have a similar effect as restarting a computer.
Get Freezer Repair in Perth from Selective Fridges
Posted on Mar 02, 2015
    Guru:
  • 1,524 Answers
Head pressure should be around 250#.
Be sure condenser is clean. Use a good foaming cleaner.
Posted on May 29, 2010
  • stanley jones
    stanley jones Aug 29, 2014
    cleaned cndenser coils
  • stanley jones
    could it need to be charged
Our Kenmore 253.28432801 is just over 5 years old. It stopped freezing, and the Sears tech says it has a leak and needs coils and a condenser. This would be $618, he suggested we buy a new freezer. Co
If it's holding at 28 degrees, it's not the coils. See if dropping the temp does any thing to lower the temp. If it does, fine. If not, most likely just the control needs replaced or just cleaned.
Nov 15, 2014 | Kenmore Freezers
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
The freezer doesnt go below 0 degrees anymore it goes 27-28 degrees . What could be the problem?
A defective temperature control can cause that problem.
Check by dialing it, it should be smooth when dialed.
It should be on desired degrees where you set it and not on other.
Thanks for asking.
Jun 27, 2011 | Coldtech 40 cu. ft. / 1133 liter...
Our under the counter freezer will not cool below 28 degrees. What are your thoughts?
Hi.
Try doing a defrost. If the freezer works after defrost, then it was the defrost system. If the freezer has auto defrost (evaporator comprising thermostat, timer, fan and heater), then the problem may restart after few days. In that case the problem is one of the parts comprised in the evaporator.
If the freezer does not cool after defrost, then temperature control (depending on model) may be responsible. Compressor and gas leak usually result in no cooling at all.
Regards.
Ginko.
Feb 11, 2011 | U-Line Freezer Origin Series 75FB 6 Cu....
Freeezer is only freezing around 26 degrees
Dirty condenser, condenser fan motor is not running, freezer overpacked, bad thermostat, evaporator ice build up and it blocks the air flow. evaporator fan motor is not running or sealed system problem.
Mar 14, 2010 | Freezers
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Apr 20, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
461 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
