Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv want go on
Turn on power butten turns on green goes back off but tv never turns on
  • 1 more comment
  • Anonymous Apr 07, 2008
    Mitsubishi WS-65809 HD 1080
    Turn the TV on the green light comes on for 4 to 5 seconds then is off.
    Need help.
  • theddy Apr 19, 2008
    i accidently lock the front button browsing tru the menu. now tv can not go on
  • snoopn125 Apr 20, 2008
    I have the same problem, have you found a solution? I've done the menu and input and it blinks 2-2 but what's next?
The green light came up as 1-2 as you said but still tv does not turn on. is ther a way to reset it?
Posted on Apr 19, 2008
  • 170 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Posted on Apr 09, 2008
My magnavox hdtv won't turn on no green or red light on the power butten no power at all
Start with the obvious. Is your TV plugged in? If it is on a power strip, does the strip need reset? If all is normal there, then unplug the set and take the back off. Check your fuse to see if it is blown.
May 17, 2012 | Televison & Video
GE Model# D52GW12 Television works good for
The small signal board is usually at fault when that symptom occurs. You can get replacement boards from
Apr 02, 2010 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Set turns on and then goes off sometimes it will go back on sometimes, sometimes not. Makes a clicking sound when it happens. Happens whether the set has been on a while or not. model is vs-60801 made in...
that is an old sob but if it is projection then check the power butten on the tv might be stuck in or the remote might be sticking or check the battery that is suposed to save the memery in the tv
Jul 12, 2009 | Televison & Video
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Hello hope. Try pushing in the input and menu buttons on the set and hold them both in together for 8 seconds to see if the Led will blink a two digit code then let me know what that code says. I can get you a link where to get a new power supply, but that may not be your problem. Try this test an see what the led blinks if anything then let me know I will try to help you determine whats wrong. I am a specialist with mitsubishi projection units.
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Dont have a remote
A green blinking light usually indicates an internal problem. The service person can use the pattern of the blinks to determine the problem.
Jan 08, 2008 | Mitsubishi WS-55613 55" Rear Projection...
TV does not not turn on
These flat panel tv's all have a problem with bad leaky capacitors. look for any capacitors ( round cylinder shape with a metal top) that have the top rounded over (bulged up) that part would be bad.
Jan 02, 2008 | Sylvania 6632LG 32 in. LCD HDTV
Mitsubishi WS-65809 65" Rear Projection Television Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
