Question about Sony Handycam CCD-TRV68 Camcorder
Record switch when i try to start recording it wont start. it plays back recorded tapes and only sometimes will start recording i assume it's the switch where can i get a switch?
  • 169 Answers
In sony service center they replace the whole assembly of the switch including the vcr and camera switch..in our shop we replace that carbon contact switch to a metal contact...
Posted on Apr 13, 2008
6ya staff
SOURCE:
Problem with recording/playback
If it plays back a pre-recorded tape OK, then the tape head will be good. If it doesn't you might have problem, with either the head or the pre-amp stage.
However if it is playing back OK but not recording, then you have problem in the record circuit. Some tape decks physically switch the circuit when you press record. Pushing the record button will cause a switch to move position. In some cases dirt or dust can get into the switch and it doesn't connect properly. Switch cleaning fluid will correct the problem.
However the record circuit itself could be faulty. Perhaps an IC has developed a fault on one channel, which will need to be replaced.
Watching what happens when you press record with the top cover off, showing the workings, might point to some movement of the mechanism to reveal a faulty switch.
Jul 07, 2016 | Audio Players & Recorders
Why wont my Nakamichi 680ZX tape deck record
It is strange that people go to belts when that has nothing to do with the problem at hand. The probably cause can be a defective record enable switch or there have been some Nak decks that have a defective capacitor in the Bias oscillator circuit. The only way to find out is to do the troubleshooting that is necessary. It may need belts but that does not stop a unit from recording. The deck is playing so the problem is with the Bias oscillator turning on. I bet it does not erase either.
Jul 05, 2014 | Audio Players & Recorders
How to record live sounds
Plug a monitoring headphone into the monitor socket and try to record if the sounds that you try to record with is working. With an oscilloscope check the recording head is there a sine wave signal if not then the oscillator is kaput record switch operating correctly?what is the age of the tape itself? Was it played back a lot of times? I found this when some tapes refuse to take other recordings when used a lot
It is difficult to say what went wrong if you do not have access to the unit
May 28, 2013 | Technics RS-TR575 Single Dual Cassette...
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
"menu" button not working-wont record or play back tapes
when the light flashes it means that there is an error definetly.
turn the menu button on off position first and remove the battery.
reinsert battery and turn on recording mode.
Try to remove the tape and reinsert it and see if the operating light is clear.
let me know if the functionality is restored.
Oct 05, 2008 | Panasonic NV-DS65 Mini DV Digital...
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
Dvd/vcr/recorder
sounds like it's not set up for more than a quick record...check the settings..
Mar 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
52 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
