Question about Wacom (PTZ930AC) Graphic Tablet
The Pen appears to be locked on the click and drag.
In the Control Panel for the pen, hold down CTRL (PC) or ALT (Mac) and click on the About button to open the diagnostic screen. Look at the value for "Pressure" on the right hand side - this should stay at 0 until the pen is brought into contact with the tablet.
If not you have the same problem as me (Graphire 4).
Solution:
So I disassembled the stylus. This is a quite brutal prcedure. the upper part is actually slid over the lower part, so to seperate them hold the rubbery part tight and bend the silver upper part arround till it moves (it may crack a bit before that, but thats just a cosmetic problem. After you pull the stylus apart, pull the PCB out and notice the coils on both ends. Pull the tips out of the coils and then the coils out of their holders (the wire should be long enough). Then you have to seperate the gray part of the sensors from the black part using a small screwdriver or something similar. whenn you then bring one of the coils near the pad, the pressure should read zero.
Carefully clean the sensor parts and put them back together, check pressure again. It should still read zero. If not, clean again.
The problem is most probably that a bit of dust or a grain of sand squeezes itself between the tip and the very sensible sensor and therefore preloads it.The Pen appears to be locked on the click and - 7f2b091.jpg
Posted on May 27, 2010
I have changed my XP for a Windows 7 with Office 2010. I cannot find the facility in Word 2010 to draw lines between text, erasor, etc. (which I find very useful when constructing Family Trees.) Is there...
Almost all the features of Older versions of MS Office are available in Office 2007 & 2010.
If you are working with tables, and wish to add/ draw lines using pen and use eraser, then after drawing the table, click the drop down and select 'Draw Table' and the table borders editing options will be displayed after clicking the table (the pen and eraser). The picture below shows the steps:
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Computers & Internet
I have a sandisk 4gb, I need to put a power point presentation on it.
plug the sandisk in your computer and go to my computer and double click the pen drive. This will show the contents of your pen drive. Now you can simply find where you have saved the powerpoint and drag and drop it on to the pen drive.
Alternatively open the presentation in powerpoint. select file -> save as and navigate to your pendrive in the box that pops up (by going to my computer and double clicking your pen drive) and choose save.
Any further help needed, just ask
Nov 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Just fully charged Sony Clie'---backlight is too dim..How to adjust??
You can set your pen drag function to adjust the brightness.
Click the drop down menu on the top right of your screen, then click "system", then "prefs", then click the button at the bottom of the screen that says "pen". Next, click the drop down menu beside the little icon that looks like your clie. Click that and select "brightness". Now, when you drag your stylus from the bottom to the top of the screen, a little slider bar will appear to adjust the brightness.
Sep 14, 2009 | Sony CLIE PEG-UX50 Handheld
When i press down with my pen a second mouse point appears and cause me to draw a straight line i do not know how to fix this.
Sounds like when you click the Mouse Roller to lock the screen scrolling. You should be able to hold the pen down a second time to turn this off.
Sep 11, 2009 | Aiptek HyperPen 8000U Pro (65388600069)
I am not able to format my pen drive itz appearing that make sure no window is using the device
try this method.
insert pen drive into usb
open up my computer
right click on the pen drive and format.
sometimes when you have the folder open that you want to format it wont want to do it, so by opening up my computer and only right clicking on it, you wont be accessing any of the data on there you will be just telling it to forrmat it.
that failing you might need to search for a pen drive utility that combats these issues specifically.
Jun 28, 2009 | Pen Drive IVO MP3 Player
Bought a 2gig maxell flash pen and wanted to use it for storing my work on it but i cant seem to work it and i need to save my work on this flash pen can some one please help
If you are using Win98 the problem is the USB ports themselves. You must locate and install USB drivers to make them functional. Other than that the USB should reconise the flash pen after a few minutes.
Now if it see it, to store in the drive, Save the information to a file/folder and then right click and choose SEND TO and pick the letter drive that is your flash pen and that will do it. If you can do drag and drop open the window that has your info and open a window that shows your pen drive left click and hold it down a drag it to the pen drive - when you see the + just release the left click and it should be on the pen drive.
Hope this helps you, good luck, please leave a rating, thank you kindly
Apr 26, 2009 | Computers & Internet
My Pen Doesn't Work
ya, i had teh same problem ... i had recenlty downloaded "pen attention" its a software that some guy made to make the pen curser look bigger in one note ... i uninstalled this program and now the problem is gone!!! so just make sure that you delete any programs that you have downloaded tht might be interfeering the the tablet's performance (especilaly programs or addons that my have been developed by non-wacom personelle for the tablet)
Jan 09, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom tablet won't recognize pen
Hmm. I've had a similar thing happen with my tablet. Have you tried removing the tablet pen from the list of tools in tablet preferences and then adding it to the list again before checking the 'About' section of the tablet pen set-up and clicking the 'diagnose' button there in? As that worked for me when my tablet pen was not working. The pen was recognized by the tablet after that.
Aug 20, 2008 | Wacom Intuos3 Graphic Tablet
Kingston pen drive locked by LOCKv116.exe
i have same problem with kingston 2GB, i format my pc, also with pen drive attached , now it saying please insert message but pc will detect it
Feb 07, 2008 | Computers & Internet
Wacom (PTZ930AC) Graphic Tablet Logo
1,215 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
