Question about Maytag Refrigerators
The fan for the condensor is intermittent. When not running the centre piller gets extremely hot. I can spin the fan and sometimes it runs but often not. It's a Maytag GS2126PEDW/18 FD8205 S/No. 18061929AJ Side by Side Fridge
  • 3,230 Answers
Well the condensor fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. Clean the fan. If the fan blade is damaged, it can be removed from the fan motor and it should be replaced. Spin the fan blade, it should move smoothly and freely. If the fan does not move smoothly then you need to replace the fan motor. If the fan motor cannot be accessed for testing, remove the motor. The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing. You need a Ohms meter to check out the fan motor, please post comments for further help or information.........
Thanks
Posted on May 27, 2010
My refrigerator freezer does not cool below 70 degrees. I just relace the start relay and now the compressor runs but the condensor fan won't work unless i give it a little spin.
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn-Air JCD2389GES problems
The condensor fan cools the condensor coils. If it is running this will cause a no cool situation. Also, if the condensor coils are plugged with dirt that insulates the coils and causes a no cool situation. These things will make it so the freezer isn't cold enough to freeze water so the icemaker will not produce ice. As far as the door edges getting hot. A condensor line runs thru the cabinet between the doors and this is called the mullion. If it is too hot this is a good indication of a bad condensor motor or dirty coils. Clean the coils and check the status of the fan motor and let me know what you find and we will see if we need to go further.
Nov 11, 2007 | Jenn-Air JCD2389G Side by Side...
When i turn the A/C on, the temperature begins to rise and it begins to spill the antifrezze from the radiator reservoir. Dont know what the problem is.
You evidently have a problemwith your engine cooling system. Check to make sure that the cooling fins on your A/C Condensor and Radiator are not clogged up with dirt and debris. Check that your mechanical fan clutch has some resistance to pushing it by hand. If it spins too freely. the fan clutch could be worn out. Check to see how much air it is actually moving through the radiator. When the engine is at operating temperature and the A/C is on, This fan should be turning at a very high speed and blowing HOT wind in your engine compartment. I believe that your vehicle is also equipped with an electric cooling fan. The electric cooling fan should be running any time the A/C compressor is engaged. If not, then you must diagnose this failure.
Jan 23, 2011 | 2005 Nissan Frontier
Hp 6720s lap top running - vista does not load
If the laptop runs extremely hot, then CPU will shut down (thermal overload) and will not boot up again until it has cooled down.
Overheating problems is caused by faulty fan (stop spinning) or the fan and heatsink assembly is clogged with dust. Check the fan, it should spin freely and remove and vacuum the dust from the fan and heatsink.
Replace the fan if it is faulty.
Aug 03, 2009 | HP Compaq 6720s PC Notebook
1991 Nissan Sentra A/C intermittently shuts off
condensor fan may nopt be operating if the condensor temp gets up there the compressor will not run
Jul 21, 2009 | 1991 Nissan Sentra 2 Door
Freezer not freezing, fan in rear bottom of unit not running, condenser extremely hot to touch. ge gdl20kcsabs
Hi, If the compressor is running but the fan is not, you will need to replace the fan motor. First make sure that there is nothing stopping the fan blade.
If you have a window or box fan, let it blow on the compressor to cool it down. This will help you get by until you can replace the condensor fan motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Refrigerators
My condensor fan is not running. I looked in the
Hi, Check voltage to the fan. The fan will only run when the compressor is running. If you have voltage to the fan whilr the compressor is running, replace the fan.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 14, 2009 | Frigidaire FRS26R4A Side by Side...
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
