Question about Dryers
The flapper on my exhaust fan is not closing
Have a broan exhaust fan but the flapper is not closing all the way. It moves freely but wont stay shut
    Novelist:
  • 145 Answers
Most if not all exhaust fan flappers have a spring loaded door that will open when when the exhaust comes out and the springs will allow the door to shut completely. Check your local home store for replacement springs, if new springs are not available you may need to replace the part of the vent with the flapper on it, not very labor intensive but it is time consuming, as you need to remove whatever is being vented, like an over the range microwave or a vent hood.
Posted on May 27, 2010
The fan motor works, but is not venting the room
It might take some work, but you should be able to get at the exhaust vent by removing the grill, light fixture and fan. Might be best to try and find where it is vented to, hopefully an outside area. If you can, there are some small over the counter type of things you can use to try and clean the vent. One is a window brush that is on a long pole, found in the window cleaning area of the Home Depot. This is a soft brush that will not damage (famous last words) the exhaust vent. There is also a flapper door of sorts that closes at the fan when the fan is not running. Might be that the flapper is stuck in the closed position. Good luck!!
May 14, 2010 | Broan-NuTone N-8663RP Combination Light...
NUTONE HEATER PROBLEM
contact nutone. the problem is that the sensor that shuts off the unit to prevent overheating is too sensitive or faulty. nutone website seems geared towards selling their product so you may have to call them direct at 1-888-336-6157. this is customer support. good luck.6-6157
Mar 03, 2010 | Broan-NuTone N-668RP Combination Light Fan...
My parents had a Broan exhaust fan installed in their bathroom and water is leaking from it. Any ideas on what this could be?
Sounds like a condisation problem. Check the exhaust tube for low spots, and also check if the exhaust tube is isulated.
Nov 29, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Oct 07, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
Range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Apr 04, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Dryers Logo
375 people viewed this question
Top Dryers Experts
