Ac wont work
I have a totaline P474-1010 thermostat, but for some reason i cannot get the A/C to work at all. Help?
    Problem Solver:
  • 11 Answers
Check the input supply of voltage
Posted on May 27, 2010
How to I control this ridiculous thermostat (Totaline P310-0210) Just moved into this house and no manual, if I press buttons it says stage 1 or stage 2, I/m freezing...someone help!!
Hello Stephanie Sakata,
I found 2 (two) "TOTALINE" manuals...
These little beauties all work pretty much the same...
Put the slide switch in HEAT MODE...
Push the "HOLD".. (which keeps any/all
clocks/gadgets and BACK-SETS off)...
and ADJUST THE TEMPERATURE where you want it...
ELSE...
Read these manuals (
close)...
No exact matches found Try these results
Carnac the Magnificent
Dec 13, 2017 | Heating & Cooling
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
Why is my totaline thermostat flashing fd and not working
Factory Default. Your thermostat is halfway through the factory reset procedure for some reason. Check out the cheat sheet here:
http://www.totaline.com/dl/stat_setup_cheat_sheet.pdf
DON'T FORGET TO REPROGRAM YOUR THERMOSTAT SO IT WILL ACT THE WAY YOU WANT IT TO AFTER IT IS RESET!
If you don't know how to, just look at the cheat sheet cited above or find the model number (inside the case) and search google for an operation guide.
Jan 05, 2015 | Heating & Cooling
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
Totaline thermostat P274-0200 just stopped working...can't figure out why,
check condenser fan line. over heat condenser so have not cooling in home.no cooling so Thermostat not worked.if it's ok. check Thermostat volb lick .
May 28, 2012 | Carrier Totaline P291-1003 Capacitor 10mfd...
I have a totaline 0441...with an EH error code I can't seem to remedy any help?
It sounds like your thermostat is stuck in EMERGENCY HEAT mode programming. To Exit,
Press the FAN button. While holding the FAN button, press the UP button for 2 seconds.
I'm also attaching a link to the manual for your thermostat.
I hope you find this information helpful to you.
http://www.totaline.com/dl/P474-10101ForAllProgrammableDigitalThermostat.pdf
Mar 13, 2010 | Heating & Cooling
My totaline thermostat is blinking ''L6'' Furnace is operating ok, filter is clean. I can't figure out how to reset it and don't have a manuel.
Well..I just recently noticed this problem on mine and cant seem to find anyone to help me other than to call for furnace service..but the more i look into this ..the more i wonder if the code is L6 or Lb for low battery.
Jan 27, 2010 | Heating & Cooling
Totaline Thermostat
Hi, My totaline thermostat says EH on it and will only heat. No AC. any suggestions. Previously my AC repairman came out and added Freon into the unit. But did not fix it totally either.
Hot In Atlanta
Oct 26, 2007 | Computers & Internet
Heating & Cooling Logo
298 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
