Question about RCA L42WD22 42 in. LCD Television
The picture is hard to see it is like but the sound is just fine
No picture but perfect sound
  • R Buschy May 27, 2010
    People are going to need a lot more information on connection types to answer this question
My vizio model# E480-B2 was working fine one day and the next when I turned it on I have no picture.. Perfect sound ! Does anyone have any ideas?
Hi , The link below is a YouTube page full of videos showing how to fix a Vizio television NO picture GOOD sound, I hope this helps....... CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 09, 2016 | Vizio Televison & Video
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
My TV doesn't have any sound with its cable. The
Tries difference setting in the SOUND setting,see how it turn out.Like setting in Variable setting,instead of fix setting.Setting in MONO setting,istead of STEREO setting.
Jun 25, 2010 | RCA 32F531T 32" TV
TV's picture and sound goes off. Had to cycle Mitsu WS-55513
THERE IS, aside from having the set taken to a shop, One other thing you can try---
NOT THE RESET BUTTON ON THE FRONT OF THE SET!
If the original Mitsubishi remote works on the set---this set has a hidden menu---it also in that menu has a HARD RESET---puts set back to the condition is was when new in the box--will come back on on channel 3 in the air band and any labels you placed on any of the video inputs (ie--named a input DVD etc) will be gone.
If you have OSD but no video either you have some problem with a single voltage coming out of the power supply(shop repair) or if you had a power outage or the power cord was removed with the set on---the hard reset may fix it---nothing to lose--set is not usable now---
Let me know if you want to try the reset and I will tell you how----
REGARDS, SD TECH
Oct 26, 2009 | Mitsubishi WS-55513 55" Rear Projection...
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
No picture, perfect sound, burning smell
I assume this is an LCD tv that you have? I would think a fault has developed on your inverter board with one of the components having burnt out & shutting off the drive to the backlights hence the smell & lines on the picture. It would be advisible to take it to a repair centre to have it repaired to check the burning issue as a matter of safety
Aug 04, 2009 | Televison & Video
No picture but I have sound
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then your TV has a more serious problem, that requires the attention of a repairman.
Jul 02, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
RCA L42WD22 42 in. LCD Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
