Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Engine keeps shutting down.
I have a 16 hp Briggs & Stratton engine that keeps shutting down after approx 15 - 20 minutes of running. It will restart the first couple of times and resume running but after it shuts off about 4 times, I have to let it sit for 5 - 10 minutes before it will start and stay running. I have cleaned the carb and replaced the fuel filter but it did not help. It seems like when it gets hot, it almost seems like its out of fuel. Could this be vapor lock or could it be and electrical problem that when it heats up, the coil might not be producing spark? Please help, any suggestion is greatly appreciated. Thank you so much.
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
SOURCE: i have a briggs 20 hp intek , it run about 15 or
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Posted on Aug 14, 2009
SOURCE: Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Posted on Aug 16, 2009
  • 384 Answers
SOURCE: my friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Posted on Sep 17, 2009
Testimonial: "thanks for your answer. I was quessing that the suction(prime) was in the throat of the carb a venturi action,but I'll simply prime the fuel to it."
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
How do you replace a condenser on a 16 hp Briggs and Stratton v-twin model-303777...type 1142-E1. Note:Engine runs fine for approx 30 min(until it heats up) and then shuts off & will not restart until...
The condensor is not the problem for they go bad upon not hold a charge. When the engine heats up and the engines dies out the problem may lay in the magnito's frame mounting from swelling from the heat, a loose mounting bolt(s). Or a Magnito that is ready to go out completely
Sep 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a potable generator that will not turn off.it's a 16.5 briggs vanguard v-twin motor.i replaced the coils and the diode wiring assembly.i fill the diode assembly might be backwards.is that possible?
Are you saying the engine will not turn off? The engine shut down uses a ground on the ignition circuit to shut down. This kills the circuit that provides the spark for the engine to run. See if you can trace the circuit for the shut down and check the ground connection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Mar 09, 2009 | Briggs & Stratton 8,000 Watt 16 Hp...
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
475 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
