Question about Haier HWR10XCA Air Conditioner
What does it mean when a haier ac window unit says eo
5 Suggested Answers
  • 10865 Answers
SOURCE: Lost Manual to Heir window unit
hi there. i can help you. here is the link to haier's site where you can download a free manual. just enter your model number where they ask for it.
http://www.haieramerica.com/en/support/?sessid=8398284157804f528f7f52348d7e0ff2
Posted on Jun 10, 2009
  • 159 Answers
SOURCE: ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Posted on Jul 12, 2007
KOakaKO
  • 135 Answers
SOURCE: Haier 8000btu Airconditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3705 Hope this helps! ;)
Posted on Aug 06, 2007
  • 4736 Answers
SOURCE: previous tenant left ac window
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Posted on Jul 11, 2011
Haier AC window unit showing code "EO"
It's a "drainage system trouble" code.
The compressor run light flashes in 10 flash increments.
You should be able to check whether condensate is draining from the unit.
If not draining, that's your problem.
Sep 13, 2017 | Haier Heating & Cooling
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
My AC haier say EO what do I do
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you have any other AC Repair Questions don't be afraid to let us know.
Jul 07, 2016 | Haier Heating & Cooling
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
I am using a Haier HWR05XCJ, and the unit will do nothing but display "E0" when plugged in. Not even the power button responds outside a couple of beeps. Filter's clean, so I'm unsure...
As you have probably discovered, Haier for whatever reason, doesn't list any of the Error Codes in your Owner's Manual. To find out what "EO" means and the solution for it, you must contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Heating & Cooling
Jun 10, 2009 | Haier ESA306 Air Conditioner
Haier hwr10xc6 thru-wall/window air conditioner
Does the unit have an energy saver or timer feature? It should be on the top front panel of your unit. If so, read and follow the directions in your manual. If you still have problems, contact Haier at their toll free Customer Service helpline.
Apr 25, 2008 | Haier hwr10xc6 Air Conditioner
Jun 18, 2007 | Haier HWF08XC5 8K RAC Mechanical Window...
Haier HWR10XCA Air Conditioner Logo
1,939 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
