MY kyocera copstar cs 2550 wont fax, the red attention light goes on and the memory tx keeps displaying. How can i reset and clear the memory to clear the machine
  • 1 more comment
  • yan dikshteyn May 27, 2010
    I dont have the user manual to clear the fax memory please help om how to to do it
    need a definite solution to clear the fax memory
    awesome thanks
  • 1,555 Answers
First try a hard reset - Unplug printer from power supply, wait 5 minutes and replug. Since there is no battery inside your fax machine hence the memory will get washed out and the error will be removed.
Posted on May 27, 2010
    President:
  • 1,561 Answers
The easiest way to reset a copier is to simply cycle the power. Turn it off, wait for at least 10 seconds, then turn the power back on. Note that 10 seconds may not be enough for the copier to reset. You may have to give it time to cool down completely before turning it back on again. This works because copiers can sometimes get stuck while performing a function, and by cycling the power, you're interrupting the process and putting the copier back in its original state.
Take care
  • Sulaimon Jimoh Olayemi May 27, 2010
    Press "Menu," then press the number pair corresponding to your model of copier.
    Press the up or the down arrow key to select "1. Reset" to restore the
    copier's default settings.
    Press "Stop/Exit" to exit the menu and return to standby mode.
    You could also follow this procedure.
    According to the Copytechnet website, you may have to go into the
    copier's interface and delete all of the settings by hand in order to
    reset it. For most copiers you'll log into the administrative account
    first. Then, go into user tools, system settings, admin tools, and then
    address book management. Select each entry and delete it. Resetting the
    copier by hand is more tedious than the other methods listed here, but
    it is just as effective.
    Take care
    Genius:
  • 1,354 Answers
Hi
i hope you have user manul just refer that you know how to clear memory
or find technicle manual from folowing link
[PDF]
Copystar CS-2550 LTR [12974].indd
if not then contact me
    no i dont have the user manual, i have the fax sys manual but it doesnt instruct how to clear memory
Fax memory full
you need to cancel job in memory that did not send , or try
to turn off the copier and unplug it form outlet ,then plug back in and
turn on ,this may clear the fax memory.
Apr 07, 2014 | Kyocera Copystar CS-1820 Black and White...
The copier keeps printing the same document. There is nothing on the computer that is spooled. How do I stop the printing and clear it out?
Try this... Remove all the connection to the PC (USB, network or parallel). Turn off the printer on the power plug for about 3-5 minutes. This will clear all the documents sent previously.
Mar 09, 2011 | Kyocera CS-2550 Black and White Copier
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
Km-2550 fax machine stays busy for long periods while it has document in memory and is communicating. The product is not a Lexmark, its a Kyocera KM-2550, but thats not a choice so...
1.....connect a regular fax to the line and see if you get the same response if you do then its a phone line issue... ... now lets troubleshoot...plug a phone in and pick up the reciever... listen for static on the line... if there is static... that can cause issues... call phone company... also if its voip... that can cause issues... if so tune your voip or get filters and this might reduce it... and possibly eliminate the issue.... if not... then i would call a kyocera tech and have him update the firmware for everything on the machine... printboards... scanners, fax... main system and if it keeps happening I would replace the fax board... still happening replace main board...
Oct 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I'm try to print a PDF file by Kyocera CS-2550 but after i press print button it's not print and in the kyocera screen I see Print Mode Error
change the driver from kpdl to pcl xl, this is normal problem with pdf files. you do this from ur computer driver.
Jun 16, 2009 | Copystar CS-2550 All-In-One Printer
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
Clear a Ricoh Fax 2000G Memory
    1. If your documents have already been scanned into memory:
    2. touch the [Change/Stop TX File] key
    • check that the [Stop Transmission] key is selected
    • touch the file that you want to stop, then touch the [Stop Transmission] key in the confirmation dialog box
    • touch [Exit] to return to the Fax Mode display
    1. If your documents are being transmitted:
    2. press the red [Clear/Stop] key
Dec 22, 2008 | Ricoh 2050L Laser Fax
I can not get the fax to work on our Kyocera Mita CS-2550
Double check with the fax card if its really connected, coz usually when you cannot access to register key this means your fax card is not recognized yet, just unplug the fax card and plug it again, and check the status.
make sure you plug the phone line where it says line not T1 ot T2
and to know if your line work, hit fax buttom and then look to the screen and touch onhook buttom, if you heard the phone hook sound this means is working fine, if not check the fax card.
Regards
Nov 18, 2008 | Kyocera Mita KM-2550 All-In-One Laser...
78 people viewed this question
jasbo
jasbo
