Question about Pool & Spa
Lawn mower sttring wont wind up - Pool & Spa
  • 404 Answers
The spring is broken or has come undone from the catch, replace the recoil parts.
Posted on May 27, 2010
Testimonial: "THANKS YUOR INFO. WAS HELPFUL"
Sequence for replacing starter cord
remove housing from mower. pull rope as far out as possible and hold with vise grips then put new rope on remove vise grips and let spring wind rope in replace housing on mower .
May 11, 2015 | Garden
Why won't my ride on mower start makes winding noise ?
Check the blade on the mower. Make sure it is tight and that the shear pin has not been broken. There is a shear pin on the crankshaft that keeps the blade from turning along with the nut that holds the blade on. designed to break off if you hit something with the blade. That is so it doesn't bend the crankshaft. Also make sure that the starter works and that the gear that turns the flywheel has not broken off a tooth.
Aug 08, 2014 | Briggs & Stratton Garden
Lawn mover starter rope replacement
most starters can be taken off the engine and replace the rope without completely tearing the whole unit apart. by that I mean you should not have to mess with the recoil spring unless it is broken. remove old rope from pulley, wind up the pulley and hold it so it wont unwind, replace new rope onto pulley and tie a good knot and melt the ends of the rope so it wont unravel, then slowly let the pulley retract the correct amount of rope. if the recoil spring has unsprung on you, it will take a little time and probably several tries to wind it back up and position it back in the starter. they like to unspring while doing this so take some time and an extra person to hold and assist might go a long ways. good luck. R
Aug 25, 2012 | Ariens 21 In Classic Walk Behind Push Lawn...
Recoil spring is broken how to replace this, The rope is ok. Victor mower
take your rope off pulley then start winding pullet by hand till ti wont wind anymore line the pulley hole with the hole in the top cap slip the rope threw both holes knot the end threw the pulley hole slowly let the spring rewind the rope into houseing until it stops pull 1 foot out cut hold on to it slip threw your handle and knot it all done
Jul 02, 2012 | Briggs & Stratton Garden
Installing new pull cord and it wont retract, what did I do wrong?
You have to wind up the spring before installing the cord. Look which way the spring goes, wind it up tight, back off enough to insert the cord through the hole in the outside housing, tie a knot inside the inner pulley. Slowly let the spring recoil while allowing the cord to go in. Cut the cord to the proper length, put the end thru the handle, knot it and attach the assembly back to the mower.
Gary
Sep 08, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Pulled the cord out of the mower trying to get it back.
you have to remove the top of the mower and you may need to buy a new spring depending if it broke or not, then wind the spring up and slide the rope back through the holes and tie a knont in the rope and let the spring wind the rope back in. reassemble the top on to the engine.
Jun 16, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Broken pullcord
before you rethread it you must spin housing counter clockwise till you feel tension (if you let it go you have to restart ) then tread it
May 09, 2010 | Cub Cadet Lawn Mower Idler Pulley Replaces...
I am trying to replace the cord on my mower, but the cord wont spring back in when I attempt to start it. Please help
the spring below the cord 'spool' must be wound tight before new cord is attached.disconnect cord,wind spool in the direction cord would pull it when starting until it stops & hold it there[spring is wound] release it enough to align & attach cord.release spool & allow it to wind cord onto spool.replace cover.
Oct 11, 2009 | Garden
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Pool & Spa Logo
52 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
