Question about Kodak EasyShare V530 Digital Camera
V530 UNABLE LENS TO RETRACT OR CAMERA TO TURN ON/OFF.
KODAK V530 - BATTERY IS CHARGING. I AM UNABLE TO GET THE LENS TO RETRACT OR CAMERA TO TURN ON/OFF. LENS APERATURE SEEMS TO BE OPEN. LCD VIEWER IS BLANK (BLACK). I HAVE REMOVED AND REPLACED THE BATTERY AND HAVE ATTEMPTED TO CYCLE THE ON/OFF WHILE CHARGE CORD IS PLUGGED IN.
Charley
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
The battery is stuck in the camera I can't get it out Kodak V530
Posted on Apr 04, 2011
Lense will not retract even after camera has been charged
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Oct 16, 2008 | Kodak EasyShare V530 Digital Camera
Lens will not retract and battery charging light does not come on
The lens barrel stuck up or mechanical gears problem this is repairable .
You take the camera to local service man to repair .
You can also repair but at times you may damage . So take to repair shop.
Thanks for using Fixya
SAM ANDERSON
Sep 18, 2008 | Kodak EasyShare M853 Digital Camera
I need help!
try to remove the battery and let the camera sit for a few minutes and reinsert the battery to reset the camera
Sep 02, 2008 | Kodak Easyshare M753 Digital Camera
Hello
wekkkkc kvjbc dhbas jbsa
  • pick ur nose
  • then eat them
Jul 28, 2008 | Kodak EasyShare V530 Digital Camera
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Kodak V530
Same problem, have an M883 although this seems to be an issue with older models as well.  Something defective I am assuming.  I have taken proper care of my camera (storing it in the case, ensuring no liquid touches it, etc.) I plan to call them in the morning.
Apr 17, 2008 | Kodak EasyShare V530 Digital Camera
Kodak easyshare v530
Kodak easyshare V530 camera turns on then straight back off again bought a new battery but still does the same. Lens goes out a bit but then straight back again.
Feb 20, 2008 | Kodak EasyShare V530 Digital Camera
My kodek v530 camera wont start
My camera has the same problem. How could Kodak get away with that? Kodak V530 is a piece of garbage. I called Kodak's customer service. They offered repair for only $110. It is ridiculous, why we have to pay for manufactured defect? Take a look at the Kodak V530 on eBay. There are a lot of defective V530 up for sale. The government should review this E45 error lens issue, and have them take care of that. Or we should never buy Kodak again!!!!
Dec 22, 2007 | Kodak EasyShare V530 Digital Camera
E 45 error
Feb 23, 2007 | Kodak EasyShare V530 Digital Camera
Kodak EasyShare V530 Digital Camera Logo
347 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
