TV DOESN'T GET SIGNAL
THE TV GETS A LITTLE BLUE BOX THAT SAYS CAN'T GET SIGNAL
    Genius:
  • Televison & ... Master
  • 1,689 Answers
This may be a tuner failure, or a fault in the AGC or IF circuits. This may not be cheap to service unless it is a simple cold solder connection on one of the circuit boards in the mentioned areas.
Jerry G.
Posted on Apr 12, 2008
How to connect Sony FWD-50PX3 to cable box
that depends on the cable box you have.
Your best option is a box with a composite output - that is 5 cables (red, green, blue for video plus red and white for audio) that connect to corresponding 5 holes at the back of the TV.
This is called "Component" signal and is an equivalent in quality to HDMI.
If your box doesn't have that you're stuck with composite cable, which is just 3 cables - yellow for image and same red and white for audio; composite signal does NOT carry high-definition information, though.
It's not the cable that matters, it's the signal carried through it that has the limitation.
Hope this helps.
www.coppelltvrepair.com
Sep 30, 2012 | Sony FWD-50PX3 50 in. Plasma TV
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
I just ran the auto scan, and now the tv in a little blue box says No Signal !
because jou not heave signal or bad or the receiver is bad
Apr 15, 2011 | Televison & Video
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
Alba servic mode
THE TV JUST GETS A LITTLE BLUE BOX ON THE SCREAM THAT SAYS CAN'T GET SIGNAL
Apr 05, 2008 | Televison & Video
Panasonic plasma will not display signal
Ous worked a little odd like that also. Even the part about the pip. Try to hook the ps2 through the cable box which then connects to the tv. This worked for our dvd and wii. Hope it works.
Jun 07, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
