Question about Haier HC48C1VAR Central Air Conditioner
Compressor will not run, outdoor fan does, is there a speciall capicitor for this? I believe it's 470 vac, 60 +-5%, model hc48c1var
  • 901 Answers
Check thermostat, compressor ON relay. Finally compressor capacitor. Replace the capacitor with identical MFD value and the working voltage.
Posted on May 27, 2010
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
My carrier 38CKC (60) is blowing hot air. The fan seems to be running fine. Is it the condenser coil, or just needs freon? How do I know? The unit is about 8 years old and never been serviced (I know...I...
Assuming the outdoor unit is running, make sure the fan motor on top is turning and the compressor is running. They both must operate for the unit to function.
The easiest and most common problems:
1. Condenser coil is stopped up with dirt. The condenser coil is the radiator looking coil that wraps around nearly the whole outdoor unit. It can be washed out with water and a sprayer, just make sure you don't bend the aluminum fins and disconnect power before washing it out.
2. Low on refrigerant. If you don't have guages you can't check the refrigerant on your own. If the fan and compressor are running , feel the bigger copper line coming from the outdoor unit going into the furnace. It should be cold. If not you can either be low on refrigerant or the compressor valves are weak.
Hope this helps. If the unit is not running outside, repost and I will try to diagnose differently.
Jun 16, 2011 | Heating & Cooling
Whats the cost of the compressor fan
We specialize in cooler gaskets but we also are able to locate and sell many refrigeration hardware items like compressor fans, The fans for Victory model VUR-60-16 range from $100-$178 depending on the date your Victory unit was manufactured. If you email or call us with your model and serial we can locate the exact part your unit needs and we are often able to offer a price below list cost.
Hope to hear from you - orders@coolergaskets.com or Toll Free 855-288-2259
Thanks,
Matt
Coolergaskets.com
Dec 15, 2010 | Victory VUR-60-16 Stainless Steel...
Indoor unit freezing up
THE OUTDOOR UNIT HAS A CONTACTOR WITH THE CONTACTS WELDED TOGETHER THE CONTACTOR CONNECTS TO THE COMPRESSOR AS IT TYPICALLY PULLS A SURGE OF 20 -30 AMPS OR MORE..WITH THE INDOOR UNIT IN FAN ONLY THE COMPRESSOR SHOULD NOT BE RUNNING. THE CONTROL WIRES GOING TO THE UNIT HAVE 24 VOLTS TO THE CONTACTOR TO PULL IN THE CONTACTS TO SUPPLY 220 TO COMPRESSOR.
Mar 09, 2010 | Heating & Cooling
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
AC didn't blow cool air. Checked the compressor unit outside and the fan didn't work.
if you could hear the compressor running then capicitor or fan motor bad if no compressor check for power to out door unit some times fuses at disconnect also on seperate breaker than indoor unit hope this helps
Jun 17, 2009 | GE Heating & Cooling
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Haier HC48C1VAR Central Air Conditioner Logo
218 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
